2011-2012 FIESTA AUTOCROSS SUSPENSION KIT, 2 sets of fronts, and one set of rears
Discussion in 'Fiesta ST Parts for Sale' started by JoeHall, May 26, 2015.
  1. JoeHall
    JoeHall New Member
    Hello, this is a great used set. have about 20 hours on them. no issues with kit at all. just do not have the wrenches to adjust ride height. can be picked up online.
    included is an extra set of fronts as well! no issue to either of them, everything is in perfect working condition.
    • Fits 2011-2012 Fiesta
    • Kit includes front coilover and rear standard monotube gas shocks with performance-level valving and progressive rate coil springs.
    • Solid aluminum spring seat and lock nut allows for precise adjustment of the vehicle's lowered ride height from 30mm to 50mm
    • Threaded body adjustable range of 20 mm at both axles, while installed
    • Road-tested by BILSTEIN under motor sports conditions and fine-tuned
    • Spring plates and lock nuts made from a special aluminium alloy
    • Surface coating using Triple-C-Technology® for long-lasting corrosion resistance
    • Round threads for ease of adjustment
    • May require alignment after installation.
    Asking $600 for the kit. plus shipping. KIt is in very good condition!
  3. JoeHall
    JoeHall New Member
    call or text 401-662-6039 for questions or concerns -Joe
  4. JoeHall
    JoeHall New Member
  5. captainmorbid
    captainmorbid Active Member
    You should post this on Fiesta Faction as well. Good price, if I didn't have KWs I'd snap this up.
    JoeHall likes this.
  6. timboslice
    timboslice Active Member
    What was the reason for the 2 sets of fronts? Do they come withy the extra set of top hats?
  7. JoeHall
    JoeHall New Member
    raced 2 cars in a spec B series. just bought an extra set of fronts that i basically never ran
  8. JoeHall
    JoeHall New Member
    no just have the one set of top hats for it
