2014 Fiesta ST Winter Driving Review
Discussion in 'Fiesta ST News and Reviews' started by BRGT350, Dec 17, 2013.
  1. BRGT350
    I am sure you have all seen the test of the 3 modes of ESC, but here is my review on the total car when being used in winter conditions. I had a good 3 weeks of constant heavy snow to really learn how the ST reacts. Living along Lake Michigan, we get around 120" of snow a season, and this year the snow has been falling constantly with some totals being 7" per day. Temps have been way below average as well. The few weeks I had with the car are a good representation of a normal winter season.
    Thanks For your time and effort and congrats on the FM most post trophy :)
  4. Removed
    Agree about the mudflaps. Hopefully RallyArmor makes a kit for the ST, or Ford offers their own, I've had a LOT of snow/ice buildup.
  5. BRGT350
    I use the WRC spec Urethane flaps from rallylights.com instead of the Rally Armor ones. I just put a set on my wife's Escape to combat all the ice build up on the rockers, which then falls off into the garage, melts, and makes a huge mess. I don't bother cutting them to size, I just install them as 12 x 18 sheets with about 5-6 self tapping screws. Going on 14 years with the set I have on my Fiesta!
  6. aborbs87
    aborbs87 Active Member
    I already have a universal set bought but don't have my car yet. It's driving me nuts trying to figure out how to get them on without it. Are there enough factory points in the wheel wells to attach mud flaps to? And would you recommend using self tapping screws for the ST also?
  7. BRGT350
    Here is how I install the universal mud flaps, which I have done on a lot of cars over the years.
    With the car sitting on level ground, place a 2 x 4 behind the front wheel, below the rearmost part of the inner fender (near the door). Place the mudflap against the inner fender, slide it down until it rests flat on the 2 x 4, move it out from the fender about 1" or so in order to add some protection as the wheels are steering and throwing up debris. Take a marker or tape, and mark a few spots on the fender (I use painter's tape on the paint) to locate the mud flap vertically and cross-car. Jack up the car and remove the front wheel. Take #8 self drilling sheet metal screws with a flange head or washer and screw them into the upper corner of the mud flap. Line up the marks on the mud flap to the ones on the fender so that it will sit in the spot you intended while the car was sitting on all 4 wheels. Run the self drilling screw into the inner fender. Hold the flap from rotating, double check the alignment with the marks, and add another screw into the inner fender near the metal fender in the upper corner. The flap is now secured at the top and will hang down. Use another screw to go into the lower side skirt, and then another near the center of the car. If needed, add another in the middle of the flap. Repeat on the opposite side. It takes longer to write this than it does to do the fronts. I did it to my wife's Escape in just a few minutes.
    The rears are not as easy. You still start by marking the flaps and use a 2 x 4 to get the height and parallelism correct. My 2011 Fiesta with the body kit is really easy since it has a large flat surface with screws that work perfect for attaching the mud flap to. The ST doesn't have that, so you need to build a L bracket using some stuff you find from a hardware store or Home Depot. I use a #8 or #10 bolt, nut, and washer to secure the bottom of the L to the bottom of the rear bumper cover in front of the felt liner. Make the vertical part of the L flush with the arc of the wheel well. Line up the flap with the marks to get it in the right place, BTW, the wheel is off and the car is jacked up at this point. Shine a flash light thru the hole in the vertical part of the L bracket (you may have to drill the hole if the bracket came without one). Mark the hole on the flap where it shows up using the flash light. Drill a hole in the flap, run a flat head screw thru the hole and a nut and washer on the back of the L bracket. You don't have a lot of room to work, but it can be done. With the marks lined up, add another self tapping screw in the corner near the bumper cover, about where the quarter panel and inner fender meet. There is a metal tab that holds the inner fender to the frame rail. Drill a small hole into the tab and run a self tapping screw into the tab to secure the flap. I run a zip tie from the flap to the chassis tie-down bracket to keep it from rubbing on the wheel. The rears take a little time, but aren't too bad.
    I should really make a video showing how this is done since I get asked a lot about it. I have done 4 Focuses, 2 Fiestas, a Focus ST, an Escape, SVT Contour, and an Escort GT. I might have some pictures on my phone I can post to help show this for everyone.
    aborbs87 likes this.
  8. aborbs87
    Thanks for the great write up. Pictures would be awesome, and a video even better if you got around to it!
