2014 Ford Fiesta ST project
Discussion in 'Fiesta ST Photos and Media' started by razorlab, Jul 21, 2014.
  1. Cesso
    Cesso Member
    Damn razor, you're really going all out on this car. What drove you to get the Airtec over the alternatives?
  3. razorlab
    Size and design. Wanted something that filled the whole opening like stock and had a good sized core with well designed end tanks.
  4. razorlab
    Ok, spent all day installing stuff today. Wilwood brake kit and the Bilstein coilovers.
    I can't drive the car yet because I need to set the ride heights and bleed the brakes still. The Wilwood calipers have the smallest and cutest little bleed screws I have ever seen, they are almost half the size of a 9mm wrench so I need to go buy a new wrench for that and the Bilstein coilovers where set low as hell out of the box. The pictures below are even with me turning up the fronts about 3 turns from factory before installing too.
    The car as it sits in the photos is 2" lower in the front and about 1" lower in the rear. Going to raise the front obviously. Over all the installs went smooth, I just took my time.
    Wilwood GT rotors vs. Stock Fiesta ST rotors:
    DP6 caliper:
    Cute lil' bleeder screws:
    Bilsteins and Wilwood BBK:
    Looks like lots of room if I wanted to down to 16" wheels:
    Way too low in front:
    Ylli, LotusZX3, Kalil and 7 others like this.
  5. RodMoe
  6. razorlab
    As an update. I didn't have time to finish the car up this weekend so I won't be able to touch it again until next weekend. Need to bleed the brakes, set the ride height and get an alignment before I drive it again.
    Driving my Evo 10 this week. Haven't driven it in over a month, about the same time I've had the Fiesta. It sure is a sledgehammer compared to the FiST, but the FiST feels like a go kart compared. ;)
    btw, the bleeder screws on the Wilwood calipers are 1/4".
  7. bobjob
    bobjob Active Member
    Did you ever get the garage line pedal spacer installed?
  8. razorlab
    Installed the Airtec FMIC today.
    Fit great, easy install. There are only three things you have to remove to get it to fit perfect and that is three bolts underneath that would otherwise hit the core and eventually wear through it. So wonder no more, this FMIC fits USDM Fiestas no problem!
    Tight fit but fits perfect:
    With the bumper cover on, it looks exactly like stock, which is exactly what I wanted. :)
  9. joker96
    joker96 Member
    I've beeen so close to buying this ic. Looking like stock is the exact same reason I want it. I considered the mishimoto, levels, atp and many other and this is exactly what I'm looking for. Any difference ? Does it feel any different?
  10. razorlab
    Drove the car around today after setting ride heights.
    The suspension feels sooooooo much better than stock. The bouncy resonance that the stock set up had is basically gone and the car is super smooth and more refined feeling. EXACTLY what I was looking for. Very happy with it so far. Of course, need to still get an alignment and put more miles before I do a full review but so far so good.
    The con, at least for me, is that I have the front perches basically all the way up and it's still 1.25" lower than stock which is a tad too low for me. Kind of a bummer. Would be great for most people but I'm just not into too low. I'll see how it goes...
    I also think I might be wanting more than just 100lb/in more than stock spring rates in the future... we'll see how it is on track next month.
  11. djdennehy
    Looks awesome...
  12. razorlab
    Look! A intercooler that works! Happy to have this on the car. Works great.
    Here are two datalogs, OEM FMIC vs AIRTEC FMIC. It was the closest to the same temp log I could find. It was a couple degrees cooler for the OEM FMIC log and as you can see, the AIRTEC still kicks its ass.
    Red is AIRTEC, green is OEM.
    Starting temp OEM: 77F
    Ending temp OEM: 99F
    Temp increase: 22F
    Starting temp AIRTEC: 79F
    Ending temp AIRTEC: 83F
    Temp increase:4F
    Ambient temp for both logs - Approx 70-74F
    Kalil likes this.
  13. razorlab
    Went and got the car aligned today by Jack at Motorsports Techniques in Hayward, CA.
    I've been going to Jack for about 14 years now I think. He has aligned all my cars and does great work.
    For a recap, the car, suspension wise has:
    Bilstein B14 PSS coilovers (#47-167490)
    Goldline camber bolts (#81250)
    Lowered 1.25" front and 0.75" rear
    I set the camber bolts at full negative camber before bringing the car in to see Jack and here are the numbers after an alignment:
    Camber: Left -1.9* / Right -1.8*
    Caster: Left 3.4* / Right 3.6*
    Toe: Left 0.00 / Right 0.00
    Camber: Left -0.7* / Right -0.4*
    Toe: Left 0.08 / Right 0.13
    This is the first rear beam car I have owned so it pains me a little that I can't do any adjustment in the rear but it is what it is I suppose. I'm so used to Evos that you can adjust pretty much everything straight from the factory.
    The car feels amazing now. Turn in is awesome, almost as good as my Evo 8 was, which is no small feat. Lateral grip and stability is way up too. I'm hoping this all translates well to the track. I will find out next month!
    The brakes....
    The car just stops NOW. I'm running the Wilwood BP-20 pads up front, which is a step up from the BP-10's they usually put in the kit and the BP-20's are supposed to be their street/track hybrid pad. Braking is really amazing now and all the squirrelyness with the back wanting to come around that the stock setup had under braking is completely gone now.
    Totally happy with the brakes, especially for under $900 including the upgraded pads and the upgrade GT spec rotors. Total bargain.
    With true race pads the car will probably feel like I threw a 5,000lb boat anchor out the back on braking.
    Pedro, Firesail, Mr UFO and 1 other person like this.
  14. djdennehy
    Before you went with the Wilwood upgrades, what did you run for front pads? Where the heck can I find some better pads for the OEM brakes?
  15. razorlab
    Stock pads. Car has 1800 miles on it currently. I just gave my front pads to a buddy here in the Bay Area because OEM are on national back order and they basically looked brand new.
    I believe Porterfield, Hawk, Raybestos make pads for the stock calipers.
  16. djdennehy
    I have found several options for the rear but not the front, can anyone else shed some light on this for me?
  17. razorlab
  18. McRib 1s Back
    I just saw this and maybe I'm missing some context, but there are better pads for stock brakes. See the related brake pad threads (use key word "Porterfield")!
    My experience is with Porterfield R4 (race) compound, only. If you're looking for a track pad, this is it.
  19. djdennehy
    Not looking for a 'track' pad as much a competent Autocross pad that I can use everyday... I used to use Hawk performance pads when I raced my MK3 Supra, they were loud but got the job done and I didn't need to replace them after every race. Would you say that the Porterfields fit that description or???
  20. razorlab
    Track tires/wheels came in yesterday.
    Brand new Dunlop ZII Star Specs which just came out about two weeks ago. Looking forward to trying these out.
    Going to go wider next time but for now, these will do.
    Mr UFO likes this.
  21. razorlab
    Track tires and wheels mounted yesterday in prep for this weeks track event.
    djdennehy likes this.
