2J-Racing Downpipe (Full Race / Catted) 250wtq, $249
Discussion in 'Fiesta ST Engine Upgrades' started by joe@2j-racing, Mar 27, 2014.
  1. RodMoe
    I hope this will hold true once Joe pipes in but the Anti Fouler is really only needed to be used on Non catted DP from what i have found out it helps the rear O2 probe get a fairly good readying so it won't throw a CEL (check engine light) I Forget if it is because it think the "CAT" is not up to temp or ??
    So if you have the Sport Cat you should not have to worry..
    spangenb likes this.
  3. golfhack
    golfhack Member
    Couldn't hold out anymore, ordered the race pipe. Hopefully I can get it put in soon after I get it. I have a lot a lot of father daughter time the next few weeks. Where is the best place to get the anti fouler? They are all the same apart from size?
    Sent from my SPH-L900 using Tapatalk
  4. frismanis
    frismanis Member
    Order placed for full exhaust. :cool:
  5. frismanis
    frismanis Member
    Great news! I bought Accesstuner Race, and have been playing with it a bit, but was hoping that people would start sharing custom maps once upgrades went beyond a flash and intake/filter. ;)
  6. moshaholic2
    Very tempted. Just not too thrilled on the welds pictured. No fish scales.
    Might wait to see how these hold up.
  7. raamaudio
    Those are MIG welds and look quite fine to me in what matters, how well they hold up in the harsh turbo heat environment, not how pretty they will look buried under the car.
    What matters in welding is fusion, not how pretty it looks, you pay extra for that but sometimes in ways you might not realize. Focus to much on pretty and fusion can suffer thus have a weaker part, I have personally broken an expensive part that looked incredible but the welds were simply not done properly.
    I weld, taught myself, not the most beautiful but not bad either, good enough to have roll cages pass serious inspections and never had a failed weld on any part I have made after I got the hang of it and learned how to test my welds.
    Guy up the street from me is a highly certified welding instructor that travels a great deal teaching customers how to use their high end new Miller systems and though I was decent before, one lesson and my welding was hugely better. He stated flat out as soon as he sees a real pretty weld it automatically gets tested and many fail.
    I built a twin scroll, equal length manifold, 50 hours in designing and tack welding it together, took it to a local welder that makes prototype parts for the Air Force jets, he has won the top welding competitions in the US, had him TIG it up. First thing he asked was how long I had been making parts like that, it was my first one, said it did not need to be so perfect, he was quite impressed really. I paid a lot to have it welded up to the best of his abilities with function over form, it is not nearly as pretty as what he could of make it look like but it would never crack where he welded it!
    When making parts that do not have to have to deal with huge heat swings, will be exposed to viewing, usually amuminum, I too love those really beautiful welds and willing to pay for them:)
    Rick
  8. golfhack
    golfhack Member
    Are these going to ship today?
  9. frismanis
    frismanis Member
  10. golfhack
    golfhack Member
    Just received an update email
    Hey! Fiesta Update... The down pipes are wrapping up in production. I will update you next week with shipping information. Thanks. Kate
  11. frismanis
    frismanis Member
    Yeah, I got it too. Bummer.
  12. joe@2j-racing
    joe@2j-racing Active Member
    We are using a 1" anti fouler, nothing special and its worked perfectly. No CEL.
    Also, an unintended consequence of the full race DP, I am now averaging 34mpg without even trying. Only on my 3rd tank so YMMV.
  13. golfhack
    golfhack Member
    Do we have an ETA when you are going to get the pro tuner so we don't have to get the anti fouler?
  14. golfhack
    golfhack Member
  15. D1JL
    From what I see and hear I was very impressed.
    Until I read further.
    Was the pipe size reduction at the flange only so both parts can connect to the OE system?
    It has always been my belief that this would be the worst place to reduce the pipe size.
    So the complete 3 inch system is not.
    It has a 2.5 inch bottleneck in it.
    Would it be possible to get a system without this bottleneck?
  16. joe@2j-racing
    Dave, if you look at the OEM DP, it is barely over 1.25" at the tail by the rear 02. The 2JR DP runs at 3" for over 14", then we created a merge to 2.5", then opened back up to 3". Much like a merge collector on a header. We found this made more power than a straight 3". It combines high flow and velocity. This helps widen the TQ past the peak HP.
  17. D1JL
    OK.
    I just thought the velocity would increase better with the reduction further back.
    I may have misunderstood.
    Are you testing the Race DP with the cat sensor using a fouler?
    I am more interested in the catted DP and if there are any CEL issues at all or must you use a fouler there as well?
  18. joe@2j-racing
    We were on the phone with Braden @ Cobb and will run the catless without the antifouler but we'll turn off the CEL. We'll offer tunes with this option - catted and catless.
  19. D1JL
    I was hoping that the catted DP would work without issue.
  20. joe@2j-racing
    It does work without an issue - my apologies, I was referring the CEL from the catless
  21. RodMoe
    The Catted DP is a sweet deal for the money and sounds NO louder than the Stock monster I took out .. I did get one CEL after the install but it was a "dummy light" because the dummy forgot to plug in one of the O2 probes LOL silly old me... Car sounds great and pulls better all around.. Thanks Joe..
    spangenb, frismanis and joe@2j-racing like this.
