3M Film
Discussion in 'Fiesta ST Detailing' started by CNRGWR, Sep 23, 2014.
    CNRGWR New Member
    Just curious if anyone has used the do it yourself stuff from 3M. I definitely want to do something to prevent the same ill fates my Mustang went through on its front end. The pricing isn't bad, unless you want to cover multiple areas of the car.
  3. WScottCross
    If you're talking about the spray on stuff, then yes, i tried it. It is tricky to get it applied at the right thickness. Too thin and it doesn't peel off well. Too thick and it will run. It does work though once you get it applied. i did the entire front end with 3 cans.
    CNRGWR New Member
    That's the stuff. I really like the idea of it. I was humoring the idea of doing the entire car. Realistically? the same as you. Maybe even do the sides
  5. WScottCross
    It needs to be redone about once a year. I just put it on for the winter months and take it off in the spring.
  6. reddog99
    Sounds like this would be good for those people who have a paint color that chips easily. I have the Performance Blue, but the car isn't clean often enough for me to tell how bad mine might be. :)
    CNRGWR New Member
    I just tend to have bad luck with these things. I was also thinking about getting a real detail done by a pro and looking at getting one of the "clear bras" they offer. I'm sure it'll be more $$$.
