A/C completely and thoroughly died, and then……..
Discussion in 'Fiesta ST Chat and Discussion' started by OrangeFist, Aug 21, 2014.
  1. OrangeFist
    OrangeFist Member
    I brought my car to the dealer to have my Mountune Quick Shift installed. Nice!!
    When I drove it home, I noticed the A/C was completely dead and blowing hot air. It was colder outside!.
    Went back to the dealer: "Your tech knocked out my AC." Anyway, they checked all the connections and the tech did not make any mistake, except it just wasn't working :(. Made an appointment to have the problem diagnosed. Next morning I thought I was going to drive around in a hot car. I start the car and it worked all of a sudden, A/C was refrigerator cold as if nothing happened. Called the service writer and cancelled the appointment.
    We fiddled with the switches to now avail. Checked the coolant and it was fine. Should I have used the voice commands to turn it on and off?
    Does anyone any idea what may have happened?
  3. ISO100
    ISO100 Member
    My ac died temporarily after a reflash. No physical changes to the car. The "fix" was putting it in defrost mode. Hasn't happened since.
  4. bobjob
    bobjob Active Member
    I had the exact same thing happen after I had my quick shift installed. Ac just turned on after 40 mins of driving
  5. OrangeFist
    OrangeFist Member
    Isn't that the strangest thing? :confused:
  6. Roger
    Roger New Member
    Mine did it too after I installed the quick shift. I let it sit overnight and magically it worked again.
  7. WScottCross
    Did you guys pull the battery when you did the quick shift install?
  8. Roger
    Roger New Member
    I did with the quick shift, but the ac issue also came up with swapping the intake without removing the battery.
  9. Mikeygti
    Mikeygti Active Member
    Same here !
  10. mrtn
    I'll have to look out for this. I just installed a quick shift and removed my battery. But the only thing I noticed not working was the one touch window up and down.
  11. ISO100
    ISO100 Member
    You probably just need to retrain the limits.
  12. mrtn
  13. ISO100
    ISO100 Member
    I believe you need to manually roll the window down all the way and back up all the way a few times. Then it will do the auto down and up again.
    OrangeFist likes this.
  14. mrtn
    Ahh ok. Thanks I'll give that a try!
  15. reddog99
    There's instructions in the owner's manual for auto down and up if you get confused.
