Adding a second speedometer
Discussion in 'Fiesta ST Sales and Service' started by Ben, Feb 1, 2015.
  1. Ben
    Ben Member
    Next week, I will finally pick up my new ST! I am getting a US spec fiesta, and I will be driving in Europe. I'm aware that there is a small KPH reading on the speedometer, but I would rather install an auxiliary KPH gauge to make life easier. I'm not looking to spend more that $150. Does anyone have experience doing this?
  3. KKaWing
    KKaWing Member
    When my buddy's speedo broke on his winter beater, he used a GPS navi. to check speed. Parents drove to the states a while back and I just set up an app on their phone for speed as well. Another option is something like scanguage that plugs into the obd port and displays all sorts of stats.
  4. reddog99
    I'd vote for the Ultragage. The numbers can be bigger & easier to see (plugs into the OBD port).
    captainmorbid likes this.
  5. Ben
    Ben Member
    I forgot the OBD port was even an option, the newest car I owned, prior to the ST, was my '97 Daihatsu Terios. On that note, where is the OBD port on the Fiesta ST?
  6. iLiptiKal
    iLiptiKal Active Member
    In the pedal box above the clutch.
  7. Steve@Tasca
    GPS speedo app for the phone is by far the simplest solution.
  8. reddog99
    Does that not require a smart phone and a cell phone signal?
  9. KKaWing
    KKaWing Member
    Only if you enable "high accuracy" mode, that would use the GPS chip along side a data connection to locate you. If you set it to "device only" it will rely on GPS and GPS alone. Note the "battery saving" mode uses wifi to aid in locating.
  10. Zormecteon
    The GPS signal is completely independent from the cell phone signal. .. I've been completely out of range for phone/data, out in the boonies, and still have GPS function.
    Cligedy likes this.
