And then this happened. I'm sure it'll buff right out
Discussion in 'Fiesta ST Chat and Discussion' started by lill2012, Jan 6, 2015.
  1. lill2012
    lill2012 Member
    I normally wouldn't have driven this today, but my truck was in use so I figured I would take it slow. Apparently not slow enough. I was on the shoulder making a right hand turn into my stop. Well that never happened. I slid straight into the curb on the far corner of the entrance. Of course it was slightly downhill so I had a chance to get some speed. I spun out and smashed the curb so hard i thought the airbags were going to go off. I think it's fair to say it's going to be out of commission for a while. At least I wasn't hurt and I get to rack up some miles on someone else's car. I'm now in a Kia Rio. It only has 100 miles on it but its pretty awful. Wish me luck and if you live in the NY/NJ area, get yourself a nice set of snow tires.
  3. Cesso
    Cesso Member
    Damn! Sorry to see this mate. I hope the damage isn't too extensive, I had a similar wreck in my MR2 and luckily a new tie rod and control arm fixed it right up. Those summer tires are definitely no good in the winter, they are sketchy when the road surface is cold and slick.
  4. eRic
    uh... are those the OEM tires?
  5. BlackBird
    Ouch, sucks to hear that. Glad you're okay. This is why you don't go out on summer tires in this kind of weather.
  6. lill2012
    lill2012 Member
    my tpms sensors came in yesterday and the wheels were sent out this morning to be mounted :(
  7. BlackBird
    That's pretty rough. I hope your car doesn't take as long to fix as mine did (2 months to source a front right strut).
  8. ZREXER
    ZREXER Member
    The timing of your posting is a little scary as I am picking up my FIST today and our roads in northern Alberta look the same or worse than your pictures. I had not planned on winter tires as I will be driving the FIST approximately 3 miles from the dealership to my garage where it will sit until spring. It is mostly residential roads, so I will put on the 4 way flashers and drive like a little old lady! I know summer tires and snow/ice is like walking on ball bearings on a tile floor...
    Firesail and lill2012 like this.
  9. KKaWing
    KKaWing Member
    Why not grab some of those slip on (plastic?) tire chains? Not sure if they fit though.
  10. timboslice
    timboslice Active Member
    Maybe consider getting it towed via flatbed to your house :biglaugh:? No, seriously. The OEM potenzas are dangerous at any temp below 5 C. My office is actually about 3 miles from home and I commuted on summer tires during a weird November snow storm... it was terrifying.
    The ST supplement states:
    The original equipment tires on your ST vehicle are designed for maximum performance in dry and wet summer conditions. They are not designed for
    winter use on ice or snow and cannot be used with snow chains. Ford does not recommend using the original equipment tires when temperatures drop to
    approximately 40°F (5°C) or below (depending on tire wear and environmental conditions) or in snow and ice conditions. You must use winter or all-season tires if you will be operating your vehicle in these conditions
    Dyn085 and BlackBird like this.
  11. Ca5p3r
    Ca5p3r Member
    you would think that Ford would have an option for all-seasons...
  12. KKaWing
    KKaWing Member
    They do, when I sped out the order form, there was an option for all seasons. Supposedly it's Michelin as3's.
    ryst likes this.
  13. Ca5p3r
    Ca5p3r Member
    well. My dealership didn't know that and I couldn't find anything on Ford's site when I bought mine. Sad.
  14. ryst
    ryst Active Member
    I bought my FiST last january, and I drove it home on the OEM tires, and someone had to help me push my car into my garage, because i couldn't get enough traction to get into the garage. Flat ground, 1 inch of snow. I drove it home from the dealer in 40 degree weather, and I noticed traction issues.
    the OEM tires are NOT SAFE IN THE SNOW. They are fairly unsafe between 30-45 degrees, and they are straight up dangerous in anything below 30 degrees even with dry pavement.
    aar0n, Ca5p3r and iLiptiKal like this.
  15. BlackBird
    The day I switched tires, it was about 19 degrees out. I didn't really have any trouble driving, but if the roads had been damp, it'd be ice-skates. Get good winter tires and stay safe.
  16. ZREXER
    ZREXER Member
    I had posted yesterday that I was picking up my FIST in northern Alberta. To be honest, my 3 mile commute to my garage at home from the dealer was no issue at all. Kept the rev's low and just nursed it along. It was -18 C and we had had some freezing rain the day before on top of hard pack snow. So I was a little nervous, but really had no issues. Tires actually hooked up better than I was expecting. Now that it is safely tucked in the garage, it will not move until the snow is gone. I am not going to push my luck on the summers.
    I have lived in the snow belt my whole life, so the reality is that I drive on crappy roads 6 months a year, so you get a really good feel and a light touch when driving on bad roads (except if you have a 4 X4 truck, these idiots are most of who I see in the ditch upside down). On my company vehicle, 2013 Jetta TDI, have Nokian Hakkapelitta's on it and even on glare ice it is reasonably hooked up.
  17. Ca5p3r
    Ca5p3r Member
    Nokian Hakkapelitta.... say that 5 times fast...
  18. Firesail
    Yea, but they are really great snow tires!:) Worth every penny.
    BlackBird and RodMoe like this.
  19. KKaWing
    KKaWing Member
    Mhmmm Nokians... too bad one chain has an exclusive where I am... Gislavid is my choice. Volvo's designated winter tire brand can't be that wrong :p
  20. RodMoe
    Love me some hakk R2's mmmm slush eating beasts . Best snow tire I have used to date from generals to blizzaks
  21. ZREXER
    ZREXER Member
    Having lived in the snow belt my whole life I have had a lot of different winter tires in 39 years of driving. The Nokian Hakkapelitta's are head and shoulders better than any winter tire I have ever had, Simply no comparison. A passenger in my Jetta asked recently if I had all wheel drive as he could not believe how quickly I was getting away from stop lights on shiny glare ice. I think the translation of the Finnish word "Hakkapelitta' is something like "sticks like glue" or something along those lines!
