ATP Turbo Upgrade Testing 13.6 1/4 mile ET 103 mph
Discussion in 'Fiesta ST Engine Upgrades' started by RodMoe, Apr 8, 2014.
  1. RodMoe
    bryramos likes this.
  3. totusPorcus
    totusPorcus Member
    now the question is... can the stock fuel system deliver enough fuel to run e85. if so, we are in for interesting times.
    thats how i tuned by WRX, uses cobb access port and access tuner race, i run e85 or 93 oct gas. with e85, i get 300whp on a conservative tune running a slightly bigger bolt on turbo, cobb turbo back, slightly bigger top mount. all of the work done buy me. since the turbo, turbo back and top mount were all simple bolt ons, it was pretty easy to do and provides a significant power increase on a stock, unmodified motor.
  4. shawnin60seconds
    shawnin60seconds New Member
    That is very quick for such a tiny little FWD car. Awesome work!
  5. D1JL
    I bought two turbos from ATP some time back for another car.
    Too bad I can't trade them for one that fits the FiST.
  6. raamaudio
    I have a barely used GT3076R hanging on an equal lenght SS manifold I built, cannot use it either:(
  7. wash
    After seeing this, hearing that they have a catless downpipe and they are local to me, I drove to Hayward and bought a downpipe from ATP.
    The price was good, the welds are TIG, it was available immediately.
    Here are some pics:
  8. RodMoe
  9. wash
    That wasn't on their web site when I looked and their store front is more of an empty lobby.
    They didn't tell me they had an intercooler when I was there.
    I'm probably going to hold out for the Cobb stage 2 with all the plumbing and intake.
  10. Papi4baby
    Papi4baby Member
    I don't get it, almost everyone else says the stock intercooler is pretty good for what it is. But ATP says they quickly ran into problems with the factory unit.
    Either someone is selling lemonade or people before them lied.
  11. D1JL
    I think you are missing the fact that ATP is using/testing a different turbo with more output.
  12. wash
    I don't know for sure but it looks like the rubber intake hose, the cold side turbo piping and the downpipe are the restrictions.
    You probably don't see the effect of them individually until you fix all three.
  13. wash
    It looks like ATP has kept tuning their car.
    They have two new YouTube videos, the GT turbo running a 13.1 and beating a bunch of Hondas and a GTX turbo running 12.9 @106.
    I think the turbos used are GT25 something and GTX2860 or something.
    They have a new set of race wheels on the front and it sounds like a launch control in the Cobb tune.
    I bet they haven't found all the speed in either combo so the smaller GT turbo upgrade is probably good for high 12s and the GTX is probably good for mid-low 12s, maybe even 11s.
    That kind of speed is going to surprise a lot of people.
    One time a 458 thought I was trying to race him (I wasn't), he floors it and as I thought "this should be interesting", I floored it too. He walked me but nowhere near as bad as I was expecting and I didn't even shift out of 6'th gear. If I down shift and have enough power to run 13 flat, a 458 would just barely walk away and trust me, when a Ferrari driver can barely walk a Fiesta, they are going to be pissed.
  14. Drifter
    Drifter Member
    There is another vid out there where they ran a 12.9.
  15. ryst
    ryst Active Member
    I read someone post yesterday where they said what happens at higher boost levels is that you need better flow, not better cooling. The stock intercooler does a great job but flows like crap, flowing like crap means the air stays in longer which means it cools more, but you'll be restricted by flow not necessarily temperature at higher boost levels.
    Also every aftermarket tuner has released an intercooler for their packages, Mountune, Cobb (soon), FSwerks, puma speed, etc. While we can be cynical and say they are just doing it to make money, I have faith that these tuners know what they're doing and are giving us parts that will help performance.
  16. ryst
    ryst Active Member
    Here's the link to the video where they're running 12.9
    ghostwhite likes this.
  17. wash
    Any air-air intercooler is a compromise, some are just better than others.
    Ford gave us a nice big space but the core is physically long so the path is restrictive and the core is not the absolute most efficient out there.
    The improved cores are thicker for less restriction but its like breathing through 15 coffee stirrers instead of 10. The cores are more efficient also.
    I was just looking for EcoBoost 1.5 intercooler pics. That one is an air-water intercooler which exploits the greater specific heat of water to make a smaller core with less restriction that can suck out more heat than air-air. Of course they need a separate water-air intercooler with a pump to circulate water but you can go big on that without adding any intake restriction.
    An interesting solution is the intercooler from Levels. Its wide but they shortened it. That's good for reducing restriction but you have to make sure you have enough core which might not be true at higher power.
  18. reddog99
    One thing to keep in mind with Ford's compromise is that since this is meant to be a street car, turbo lag is undesirable, and the larger the tubing and intercooler area is, the more cubic area there is to fill, resulting in more turbo lag..
  19. wash
    I'll agree but its a minor contributor.
    When stuff like a Squire STS pretty much works as goofy as it seems, you realize that a thicker intercooler core or an extra foot of cold side plumbing are not going to have a meaningful effect on lag.
    The ATP or Cobb plumbing will spool pretty much like stock if you keep the stock turbo.
  20. moshaholic2
    Kinda puts the intake purchase to rest for me. Just got an email response from ATP as i wondered what intake they were using if any and hitting +300hp.
    They said they are using the OE air box w/ just a drop in filter.
    Pretty much proves the efficiency of the stock system. So HP wise, we are pretty good sticking w/ the stock box or the mountune design. Ofcourse they dont provide whooooooosh noises but definately do the job well.
  21. moshaholic2
    Yup, that sure isnt the stock box!
    This is the exact quote, " within current test and development phase we utilized the stock intake system and a performance filter. To date all performance modification dyno pulls, track results and road tests utilize stock intake system and performance filter. In the event we experience possible restrictive systems, we will test alternatives. So far no issues"
    But, in reality sticking an open filter down by the road like that *probably* doesnt pull much if any more air than the mountune box with its two air inlets.
    The surface area of the oe filter size is already about 7x that of even the mountune highflow intake tube. So, there is lots of air coming in.... Getting it through the test of the system at high enough velocity seems to be the issue to make HP
    __V__ likes this.
