BC Coilovers - Install
Discussion in 'Fiesta ST Chassis Upgrades' started by joe@2j-racing, Oct 25, 2013.
  1. MonsterST
    MonsterST Member
    Glad to help though I think in a different thread Joe went on to note the weight is only a little less than stock 17 inch wheels here post #9 but they doo look good...
    ronnie karlen likes this.
  4. was-an-M
    was-an-M Member
    I have a question about camber adjustment.
    My coilovers arrived today and I had a question about camber adjustment. I know Joe said they were slotted. Does that mean at the top or the bottom? Just curious incase the place that does my alignment asks questions.
    Thanks.
  5. RodMoe
    IF I recall the Top is slotted let me go look quick
  6. RodMoe
    Yes top hole on the front struts are slotted for adjustment ..
  7. was-an-M
    was-an-M Member
    Thanks. I'll look at them more closely tonight. I assume it's the 4 hex head bolts that are loosened to make the adjustment?
  8. RodMoe
    IF by 4 you mean 4 total on the car yes but it is two per side on the bolts that attach to the knuckle on the front hub area
  9. was-an-M
    was-an-M Member
    I meant the 4 Allen bolts at the top plate.
  10. stuntdoogie
    Was an M...installed yet?
  11. RodMoe
    I'll have to look when I get home in the morning I did not think these came with a camber plate adjustment only room for the 3 mounting bolts on the tops ..
  12. was-an-M
    was-an-M Member
    No. I'm gonna wait till the porter field pads come and do everything at once.
  13. stuntdoogie
    Ughh...ok you may lol
  14. was-an-M
    was-an-M Member
    You just mean the slots in the chassis of the car? That's easy enough. I'm just surprised that those can get you -2.8deg given that the stock suspension can't get anywhere close to that.
  15. joe@2j-racing
    joe@2j-racing Active Member
    I have changed and been running -2.2 deg on street and having experienced any ill effects (less braking ability, etc)
  16. AlanBDahl
    Any chance of making a set of these that are SCCA Solo legal? In other words with dimentions that are basically the same as stock including non-slotted fronts? I think there’d be a ready market for something like this as no one currently makes stock-replacement performance shocks for the car.
  17. spangenb
    No. The camber is adjusted by loosening the two large bolts that attach the strut to the hub/knuckle and tilting the hub/wheel assembly in or out in relation to the strut. The upper strut/knuckle attaching hole is slotted. The strut top is not adjustable at all due to lack of space.
  18. spangenb
    Alan that would be great for you Stock/Street guys. I have been driving on the BCs for a week now on the pitted and pocked PA post-winter roads and the ride is dare I say "perfect". Reminds me of my '08 Mustang on Koni yellows. Just the right amount of spring and damping.
  19. spangenb
    Oh ... and this is set on 6 out of 30 clicks.
  20. stuntdoogie
    Spangenb if your trying to get me excited about installing mine, its working. Sometimes I need reassurance and alittle continuous praise of a product helps :)
    spangenb likes this.
  21. spangenb
    ;) Like I said in the other thread, I am hard to impress. These units are impressing me. My only question mark is durability and Joe seems to have great experiences on that front with his Nissans.
