BC Coilovers - Install
Discussion in 'Fiesta ST Chassis Upgrades' started by joe@2j-racing, Oct 25, 2013.
  1. stuntdoogie
    Conrad Grunewald attended the Camaro 5 fest 2011 with his 2010 Hankook Drift Camaro equipped with Custom BC racing Coilovers. Conrad who's car is setup for drift with Hankook Ventus RS3 street tires was able to capture 2nd place in the Super Modified class competing against cars equipped with Hoosier race tires.
    joe@2j-racing and spangenb like this.
  3. joe@2j-racing
    joe@2j-racing Active Member
  4. joe@2j-racing
    Stiff is really stiff.. So you can dial it up to 10 clicks on the street. I love how these ride. I'm really happy with the rates I chose!
    stuntdoogie likes this.
  5. stuntdoogie
    Im 8 clicks from soft front and rear and feels much better. Had the preload up front tightened up a little because it felt like it lost some turn in response and the front end felt heavy. The car feels great in a straight line but needs more tweeking for cornering cause im experienceing a bit of understeer in cornering speeds in areas where my car with the stockies handled with ease.
  6. joe@2j-racing
    What are your alignment specs?
  7. stuntdoogie
    Stock specs
  8. joe@2j-racing
    Run at least -1.5 camber, 1/8" toe in, and then stiffen the rear to get more front bite
  9. RodMoe
    So Joe would you say go FULL hard for the AutoX stuff and track days ? that one adjuster on drivers side front is a hoot to get to if you have meaty hands :) lol
  10. joe@2j-racing
    I run on 22 front, 25 rear at the track. I havent had the need to go full stiff
  11. RodMoe
    So many way this could go sideways LOL but will keep it on track and make a note of the settings ..
    Also do you have a easy way to get to the drivers side Front knob for adjustments ??
  12. stuntdoogie
    Just wanna say again I love the comfort of these coils at my settings. No more rattled brain. Feels like im driving a FoST now with the aofter settings lol. My FiST is now a plessure to drive in NYC. From fender to ground all around it sits at 23 1/2" but i think im gonna lower the front a 1/4 more for a forward rake look.
    RodMoe, Firesail and spangenb like this.
  13. stuntdoogie
    Whats the proper way of raising the height on the rears? I wanna raise the rear about 1/4" -1/2". Im doing this myself with just a jack unfortunately.
  14. stuntdoogie
    Anyone?
  15. frismanis
    frismanis Member
    Done. Did it in my garage this morning. Still need to adjust ride height and get alignment done. Pretty simple. Could have used a helper, but was manageable as a solo project.
  16. joe@2j-racing
    Looks great!!
    Your height is about the same as mine
    graynicolas11 and quiznos like this.
  17. stuntdoogie
    I dont like green except yours Joe :)
  18. quiznos
    quiznos Member
    Hey Joe, got anything that I could use to raise my ride height a bit. Trying to figure out the best way to cram some rally tires in there.
  19. joe@2j-racing
    Yes i can make a rally set of coilovers. Just tell me the clearance you require
  20. quiznos
    quiznos Member
    Adjustable height from 24 to 26 would be best. Might be too big a range, but 615mm plus "bump clearance"
    Generally this is done by screwing with the body and lowering the suspension, but I can't do a whole lot of body work yet. $$$ is short atm, damn taxes, but once it's avail it'll be in your pocket.
  21. D1JL
    (from the Old Farts thread)
    I moved this to a more correct thread.
    I did not even know there were two types of rear springs.
    Mine are the barrel type.
    What is the difference?
