Best Track/Street Tires <$150
Discussion in 'Fiesta ST Wheel and Tire Upgrades' started by DirtyBlueshirt, Mar 20, 2014.
  1. DirtyBlueshirt
    DirtyBlueshirt Active Member
    I'll be getting a set of ST rims soon and want opinions on the best mixed use tires I can get for about $100 per tire ($150 pt max). Until I get dedicated track tires, I want to get something that will offer me good performance on the street (generally dry conditions but not something that would kill me in the rain) but at the same time be good and grippy and able to take the punishment of the occasional track/autocross event.
    Will probably be buying this weekend.
  3. was-an-M
    was-an-M Member
    Summer tires or all-seasons?
  4. DirtyBlueshirt
    Southern California, so there's not a real need for winter traction. Either would be acceptable.
  5. was-an-M
    was-an-M Member
    You're options are kind of limited in the OE size. I would say the RE050's are probably the best bet but they are a little over your budget. $100 doesn't get you a lot of tire unfortunately.
  6. meFiSTo
    meFiSTo Active Member
    HPDE/Track day related comment (I do not Auto-X)...
    In the specific size (given your limits), there are not many options:
    Falken RT-615K $139
    A little bigger, but I've heard they fit fine:
    Dunlop Direzza ZII $152
    Falken RT-615K $145
    I've used the prior version of the Dunlop Direzza ZII with good results and the Falkens as well (drove through 3 generations of those Falkens on my prior FWD HPDE track car).
    These are both great performance values that are safe for driving to and from the track. Neither is stellar in heavy rain, but can stand a damp track.
    My experience after about 15 minutes of going all out, is that both will get overheated (sometimes called "greasy"). So, best lap times occur early in a lapping session (thinking of an HPDE-styled open track day). Or, if you go easy on the front half to warm tires up a little gradually, then you can go hard from about the 1/2 to 3/4 mark, but they are street tires and will overheat.
    I don't know that any of the street-oriented extreme summer performance tires would avoid overheating, but some do better in wet weather and might last longer. Those cost more and might not be available in these tire sizes.
  7. wash
    BFG Rival 205-50r15 $115 each with a $50 gift card when you purchase four at the Tire Rack, that comes out to $102.50 each.
    They are said to "wear like stone" maybe that's good enough for street use?
    If you get 15" wheels the tire sizes will remain some of the cheapest available with performance tires made for Miatas.
  8. wash
    Oops, I didn't see the used ST rims bit.
    15" tires would be a bit of a stretch...
