Bilstein struts...
Discussion in 'Fiesta ST Chat and Discussion' started by ted lorendo, Aug 9, 2014.
  1. ted lorendo
    ted lorendo Member
    Alright here we go...
    My friend who works for Bilstein hooked it up. They ended up fitting the PSS B14 monotype coiliver on my car. He had the Bilstein engineers fit the coil over to perfection. As it sits now, the front is one inch lower and the rear is 3/4 inch lower.
    The Ride: first right away the car hooks more. The stock suspension is good but has a twin tube tube design meaning it cant react to the raod as well as a monotube. The B14 is a monotube design. Bilstein prides themselves off the mono tube. This coilover keeps the tires/car planted on the road. I'm seeing a whole lot more traction. For example, second gear wot in a 90 degree turn, I used to fight the front tires for control, now the grip is there and it points and goes. I'm extremely impressed with the outcome. For the price it's a no brainer. Bilstein is I'm my opinion the best. It's proven. Look at the awards.
    Anyways, it may sound like I'm trying to sell you on the B14. I don't need to. They sell themselves. If you live in southern cali and want to test them out, I'm always down for a meet.
    driving it home in cruise mode was the best. My wife complained about how "bumpy" my car felt. After riding in the new setup, she's a lot happier. Two birds with one stone. The ride is a lot smoother.
    Again sorry for the delay.
  3. moshaholic2
    Hope they come out with standard sport struts and shocks.
    A bunch of us have been running the coilovers for a while now. You have to run the fronts on the highest height setting or the drop is REALLY low.
    timboslice likes this.
  4. no-pistons
    no-pistons Member
    So when are they supposed to be released?
    MOFiST likes this.
  5. ted lorendo
    ted lorendo Member
    Struts are still in r and d. So far just coilover is all they have as of now.
    MOFiST likes this.
  6. no-pistons
    no-pistons Member
    Are the coilovers that are fitted on your car the same coilovers that are available for the regular Fiesta, or are they a new FiST specific coilover?
  7. ted lorendo
    ted lorendo Member
    I believe they are one in the same
  8. no-pistons
    no-pistons Member
    Here is the new part number for the Bilstein B14 Fiesta ST specific coilovers: 47-242043. Its a different part number than the regular Fiesta coilovers and is actually $140 more for some reason.
  9. Chris G
    Chris G Member
    Eric - do you have these one your car?
  10. no-pistons
    no-pistons Member
    Not yet, but I plan on getting them eventually. First I need some 15x8 wheels haha.
  11. MOFiST
    MOFiST Member
    I'm curious is the part number you've listed the same as the part that's been available for a while or new?
  12. no-pistons
    no-pistons Member
    The number i listed is a new ST specific part number
    MOFiST likes this.
  13. who sells those coilovers? Ive been searching
  14. MOFiST
    MOFiST Member
    Yes any links and or info would be welcome. Google gave me German sites. I hope they make these with a more modest minimum drop as the b14's razorlab used are unsuitable for my needs.
  15. no-pistons
    no-pistons Member
    They are in "coming soon/back ordered" status. Maybe still in production, I assume. However, any Bilstein dealer can order them once available.
    Just FYI on these new coilovers : Front Lowering Range: 10-25mm
    Rear Lowering Range: 5-25mm
  16. do you lower the height by twisting the coilover body/shaft not by the springs?
  17. MOFiST
    MOFiST Member
    Oh yeah! These are gonna be mine. B)
  18. KKaWing
    KKaWing Member
    Part Number: 47-242043
    Series: B14 (PSS)
    Position: Front and Rear
    Descriptor: Front Lowered Height: 25-40mm, up to 850kg Axle Load
    Descriptor: Rear Lowered Height: 20-40mm, up to 765kg Axle Load
    Quantity Per Vehicle: 1
    Finish: Dampers: Zinc/Springs: Blue
    from bilstein us site
  19. KKaWing
    KKaWing Member
  20. boost rooster
    boost rooster New Member
    Would we need any sort of camber adjustment for this kind of drop? Im so tempted to buy a set, I just need to talk myself into it :)
  21. KKaWing
    KKaWing Member
    Nothing a set of camber bolts can't handle?
