Black vs silver intercooler efficiency
Discussion in 'Fiesta ST Engine Upgrades' started by WScottCross, Jun 17, 2014.
  1. WScottCross
    Interesting test proves that black intercoolers are better at reducing heat soak while you're not moving. This test was done outside a car and away from other heat sources. They also used a hair dryer as the heat source so the temps were significantly higher than we would see in our car, further reducing the real world results. I think there is still a possibility for some advantage of black intercoolers while we're sitting in the queue at an autocross. Maybe a few degrees, could be useful. At least it proved that black is not worse and I was considering black if I decide to upgrade the FMIC.
    Firesail and BlackBird like this.
  3. marc89gti
    marc89gti Active Member
    Now that you mention that, most radiators are black in color.
  4. WScottCross
    The more I think about it, the less I think their test was valid. Their hair dryer was putting out 273 degrees F. That is so far outside the normal charge temperature range that I honestly don't think we'll see any real measurable gain in the car. At least they proved it's not worse, so going with a black intercooler is more likely a purely cosmetic choice.
  5. Sekred
    Sekred Active Member
    You would be surprised at the compressor outlet temps.
    Intercooler efficiency test. Airtec vs stock, Fiesta ST 180.
    Fast Ford magazine intercooler test - measured in degree's C
    • Standard
    • Run 1 Intake temp turbo into intercooler 140 out of intercooler into engine 85
    • Run 2 Intake temp turbo into intercooler 131 out of intercooler into engine 92
    • Run 3 Intake temp turbo into intercooler 140 out of intercooler into engine 97
    • Airtec
    • Run 1 Intake temp turbo into intercooler 140 out of intercooler into engine 31
    • Run 2 Intake temp turbo into intercooler 150 out of intercooler into engine 38
    • Run 3 Intake temp turbo into intercooler 152 out of intercooler into engine 39
  6. meFiSTo
    meFiSTo Active Member
    That's some real temperature drop right there.
  7. WScottCross
    Those are some incredible numbers. To the point of unbelievable, really. Based on those numbers, the temps should be near the point of boiling water with the stock intercooler. Even after spirited driving, the intercooler is only warm to the touch on the inlet side, and cool to the touch on the outlet side. I find it very hard to believe that the stock intercooler is THAT inefficient. I think I may have to do some instrumentation on my car to get a true baseline on those numbers. I think the old adage applies, if it seems too good to be true.....
    myrightfoot likes this.
  8. SirSlaughter
    SirSlaughter Member
    Like I said on their video when it first went up:
    BRB, painting my intercooler black.
    envyist likes this.
  9. Sekred
    I agree the temp drop numbers from the Airtec intercooler do seem optimistic. I have no idea how the test was preformed.
    The Turbo outlet temps are in the ballpark. I have seen intercooler efficiency testing with compressor outlet temps as high as 300f at 15psi.
  10. Redlinez
    Redlinez Member
    wow, time for some primer and black paint!!! That was really cool....literally.
  11. WScottCross
    I'm still not buying into it until they test it in an actual car to see the real world gains.
  12. Redlinez
    Redlinez Member
    True, but it would only cost you the primer, paint, and some time to do it.
    envyist likes this.
  13. WScottCross
    Time is the hard part lately.
