Check engine light and wrench :-(
Discussion in 'Fiesta ST Sales and Service' started by Mikeygti, Sep 13, 2014.
  1. Mikeygti
    Mikeygti Active Member
    My car is on the back of a flat deck as we speak. Noticed a roughess to the engine, followed by check engine light and wrench. Then started running REALLY rough and then stalling. Started it back up, check engine light was still on and wrench was off. Wrench and stallin came back shortly. BLAH !
  3. EcoBeast
    EcoBeast Member
    Sorry to hear about it. Keep us posted.
  4. RodMoe
    Stock ? Or Tuned ?
  5. Mikeygti
    Mountune MP215 tune/ full intake & quick shift kit ( both registered with Ford Racing Warranty ) also have a Cobb CBE & RMM but they shouldn't come into play ?
  6. mrtn
    Ah! Sorry to hear it. Keep us posted. Did you happen to use the mtune to check the engine code?
  7. RodMoe
    yes keep us posted
  8. Mikeygti
    I didn't have the mtune with me to check the code.
  9. mrtn
    Darn. Would have liked to know how it worked. Any ideas why the car would have died? Running 87 octane? Low on oil? Just have me worried cuz I'm running the same stuff. Minus the Cobb exhaust...
  10. Mikeygti
    I always run 94 octane. Can't say I've checked the oil recently but no apparent leaks. These cars are t really oil burners either are they ? Had the short shift kit installed at the dealer last weekend. Hmmmm
  11. mrtn
    Hmm. I don't see the quick shift doing anything. Unless the dealer broke or bent something during the install. I know one member here had an issue with that.
  12. Mikeygti
    Fingers definitely crossed....they gave me a Fusion as loaner. The things the size of a tank compared to the FiST lol
  13. EcoBeast
    EcoBeast Member
    I disconnected a total of six items (hoses and sensor connectors) when I installed the short shift kit. I took pictures as I was doing it to remind myself what to reconnect.
    Maybe something was not reinstalled properly ??
  14. Mikeygti
    That's what I'm betting on at this point
  15. Randy@mountune
    Randy@mountune Active Member
    IIRC a customer a while back damaged part of the harness during a quickshift installation causing the the same issue.
  16. Ronbo
    Ronbo Member
    This is it probably. They way you describe what's happening it sounds like a vacuum leak, based on my experience working on simple cars. Could be one of those new-fangled sensors not fully plugged in.
  17. Mikeygti
    Heard from the dealer. Error code from cam position sensor . They couldn't get it to act up in the shop so feel it's a faulty sensor. Installing a new one tomorrow and should be good to go.
  18. Mikeygti
    Still in the shop....wrong sensor was shipped to them. In the mean time still driving the loaner Fusion. Not my kind of car, but well put together, and a bit of a looker;)
  19. MonsterST
    MonsterST Member
    When Ford dealer installed my short shift they knocked off a vacuum line causing an error code...
  20. Mikeygti
    2 weeks since the sensor replacement, and car has been running great with no more error codes ( touch wood lol )
    It was nice signing the work order with a "0" balance due with warranty coverage.
    TapTapPull, Firesail and SpaceFish like this.
