Clutch Pop
Discussion in 'Fiesta ST Maintenance' started by Ben, May 14, 2015.
  1. Ben
    Ben Member
    While driving today, I started to feel a pop when releasing the clutch, just in the top inch or so. Everything seems to be functioning the same; however, it is really annoying to have the pedal pop my foot up every time I shift. Has anyone had this happen before?
  3. BRGT350
    Yes, mine does it as well. The noise is kind of temp related where some days it is horribly loud and persistent with every shift. On days when it is either warmer or colder, the popping is less and not there at all. Right now, it pops like crazy!
  4. haste
    haste Member
    Interesting, I have yet to notice this. I'm driving a '15 with 12k on the clock. I've also tracked it two days and did one autox.
  5. Ben
    Ben Member
    I don't actually hear a sound, I just feel the pedal pop up. I took it to a dealer (the repair center was closed), and I compared it to an ST in the shop. I could feel a slight pop when releasing the clutch pedal of their show model, but it was significantly more mild than what I am feeling in mine.
  6. vixenlotus
    vixenlotus Member
    I had a MAJOR problem with my car. The clutch pedal started doing this and then started coming up slower and slower. With the car off step on the clutch and lift off as fast as you can. With my car there was a pronounced delay in the clutch coming up.
    TO make matters worse, they really screwed up my car when they fixed it. (the gear box had to come out to replace the slave cylinder).
    I will never never never buy another ford again or bring my current car to a ford dealer to fix.
    good luck, i hope the same thing is not happening to you.
  7. Ben
    Ben Member
    It turns out I'm just not used to new cars. I've never used a hydraulic clutch, so it'll take some getting used to!
