Cobb acessport for beginners?
Discussion in 'Fiesta ST EcoBoost™ Tuning' started by crzyworm623, Nov 2, 2014.
  1. crzyworm623
    crzyworm623 Member
    Quick version: Looking for what to monitor and data log to make sure the car is happy and running safe.
    Expanded: So I'm fairly inexperienced when it comes to tuning. I've looked around on the forums but haven't quite found the info I'm looking for, at least not in one easy to read location.
    I'm just finishing up installing Cobbs stage two package. I plan on running Cobbs ots stage 2 93 map.
    My question is can someone put together a list of parameters we should monitor / data log to make sure the car is running safe.
    I know Cobbs ots are relatively safe as long as you have the correct mods and gas, but I'd like to know for sure. Maybe my 93 gas from Hess is crap so I should run 91 map instead.
    I'm pretty sure ignition correction is a big one. But what about the acceptable range for afr, intake, coolant, oil Temperatures , knock and anything else I should be aware of that might send a red flag that something isn't running right.
    There's so many monitors and things I've never heard of. I'd really appreciate the help.
  3. Randy@mountune
    Randy@mountune Active Member
