COBB Alpha Firmware - Testing Needed
Discussion in 'Fiesta ST EcoBoost™ Tuning' started by COBB, Jul 10, 2014.
  1. COBB
    COBB Active Member
    ***IMPORTANT UPDATE 7/14/14***
    We have resolved a bug that resulted in the incorrect display of the "HDFX Table Weight" monitors. This has been resovled in Alpha FW 8725. Please update again to obtain this fix!
    We've put together an Alpha firmware for those of you who have experienced excessively high or low values when live monitoring or datalogging. This also addresses the issue of flickering shift lights. If you have had any of the mentioned behaviors with your Accesport V3 please perform the following steps to install Alpha firmware on your Accessport.
    1. Within Accessport Manager 2.0 navigate to the "Options" tab.
    2. Click on the Advanced>> button.
    3. Place a check in the "Use alternate update location:" box.
    4. In the new text box enter the following URL: http://www.accessecu.com/support/accessport/alpha
    5. Navigate to the "Updates" tab
    6. Click the "Check for firmware update" or "Begin firmware update" button.
    Once this update is complete please put the live monitoring and datalogging tasks through their paces and report your feedback in this thread.
    Thank you for your participation.
    -Braden @ COBB
  3. spangenb
    I will give this a try as soon as I get home today :) Thanks for the support Braden!
  4. onederer
    onederer Member
    Thanks for working on this guys. I'll DL when I get home and report back.
  5. spangenb
    Braden, just to be clear, I won't need to reflash the car to test this right? I just need to update the AP and plug it back into the car?
  6. COBB
    COBB Active Member
    That is correct, just load the firmware and use as normal. No flashing required.
    -Braden @ COBB
  7. Randy@mountune
    Randy@mountune Active Member
    Cool deal. :cool:
  8. spangenb
    Ok my AP is updated so I will get to test it on the drive home at 5 :)
  9. spangenb
    Initial indications are good :) Drove home and pushed it to max boost many times and no more bogus max reading :)
    COBB and stuntdoogie like this.
  10. puddleboy
    puddleboy New Member
    Same here, drove around about an hour on and off highways, no bogus readings either!
    COBB likes this.
  11. ghostwhite
    ghostwhite Active Member
    FYI Cobb, when I switched from 5 gauge to 6 gauge all my false reading disappeared. This is on the older firmware that's nonalpha
  12. spangenb
    I've been using the 6 gauge display all along.
  13. onederer
    onederer Member
    So far so good. Boost readings were never an issue, and that trend continues! The Estimated torque no longer reads 377+ while driving like a regular schmo. YAY!
    I was running 6 as well, I tried everything from 1 all the way to 6.
    Thanks for the efforts guys!
  14. COBB
    COBB Active Member
    Hey guys, just updated the original post with some important news regarding the Alpha! Please revisit and grab the latest for these changes!
    Cheers,
    -Braden @ COBB
  15. Firesail
    Just reflashed mine and will test tomorrow. Thanks for the great service!:)
  16. joker96
    joker96 Member
    X2 hopefully all this weird numbers go away. My estimated torque says 370 all the time except when logging thats just 1 example
  17. sourskittle
    sourskittle Member
    Mine has worked perfect since installing. No false readings !
