Colder spark plugs
Discussion in 'Fiesta ST Maintenance' started by RDgolfer, Nov 15, 2014.
  1. RDgolfer
    RDgolfer Active Member
    Maybe you are trying to discredit Randy Robles' tunes because you are Freaktuned? Who knows, who cares...
  3. Dyn085
    Dyn085 Active Member
    I never said you bumped this thread. You either fail at comprehension or just like adding words/meanings to what other people say...
    And no, I have no need or desire to try and discredit Randy. He's been a valuable asset to this and other communities that I've been part of, and he's good at what he does. Lots of my friends have his tune and love it. Just because I went another route doesn't mean that I think he's bad.
    Bavarian likes this.
  4. RDgolfer
    And...you can pump 93 octane into your car, and it could really be water, and that means 0 octane...you're a boob
  5. Dyn085
  6. RDgolfer
    "Based on the information you've given" really?
  7. Dyn085
    Really.
  8. RDgolfer
    Thanks for cleaning this shit up...this guy is an idiot...I love mountune
  9. razorlab
    Is this where the sixteen year olds hang out?
    Dyn085 and timboslice like this.
  10. Dyn085
    Yes.
    Any input from a tuners standpoint?
  11. onederer
    onederer Member
    RDgolfer, up to his same M.O. I see.
    Oh, look...this...forum...has...an...ignore function...*enabled* No more RDgolfer annoyance.
    Firesail and Dyn085 like this.
  12. razorlab
    Yea, don't feed the trolls.
    Firesail, timboslice and Dyn085 like this.
  13. Randy@mountune
    Randy@mountune Active Member
    Additives and blends for different seasons and ethanol being added can play a part. I see it in the data all the time. For example, ethanol free 91 octane gas looks a heck of a lot better than E10 91 octane gas when you compare the data. Regardless of the actual octane reading, the additives can have an impact on the knock threshold. There's no question about it.
  14. RDgolfer
    No, this is where Ford Fiesta ST owners hang to talk about their cars and what they are experiencing...enough said
  15. razorlab
    And yell out insults and have temper tantrums? Cool story, bro.
  16. RDgolfer
    I smell bait
  17. Dyn085
    To make things better, it sounds like the plugs you ordered to fix your problem because "SCIENCE!" are actually not even suitable replacements for the OEM plugs. Coupled with you finding out that you had a tune issue, I'll re-quote my advice in the first post (bold added)-
    Bavarian, Firesail and FORZDA 2 like this.
  18. RDgolfer
    You are lost in the woodz man...you should not post anything else here
  19. razorlab
    Fixed for accuracy.
    Bavarian, Firesail and Dyn085 like this.
  20. Dyn085
    So I give you the advice that is exactly what you later find to be true, and I'm the one that's lost...
    Fwiw, I don't think running a 91 octane tune on 93 octane fuel is an acceptable solution. It will work of course, but it makes more sense to be tuned for the fuel you're running-financially speaking, anyways. If you have to run the 91 tune then I would run 91 fuel, and if it begins knocking again then get back with Randy to have it corrected. If you plan on tuning 93 then get your 93 tune corrected.
    On deaf ears of course, but advice nonetheless.
  21. razorlab
    LOOK, DONUTS!
