Colder spark plugs
Discussion in 'Fiesta ST Maintenance' started by RDgolfer, Nov 15, 2014.
  1. RDgolfer
    RDgolfer Active Member
    If you want to be uninteresting, there are many other places to go...but I am a real FiST owner, and I will stand my ground...and I am a little sarcastic at times...check my last post...ha ha...and it's ok Dyno...we'll work it outo_O
  3. RDgolfer
    Razor the brain doc...I love you man! Everyone needs to post all the shit in their head....go for it...if not, all forums are worthless...let's not turn this into a communist forum...which so far this is totally not! I will spill my mind until someone thinks my mind is rotten...is it? not
  4. razorlab
    Again, wow.
    Firesail, RDgolfer and Dyn085 like this.
  5. RDgolfer
    Again, thanks for responding....wow
  6. Dyn085
    Dyn085 Active Member
  7. RDgolfer
    I am wow!
  8. RDgolfer
    This is great..91 oct is 91 oct...summer is no different than winter gas...
  9. Dyn085
    This discussion is completely useless if you're going to keep rearranging the words into things I've never said.
    91 octane fuel should carry a minimum of 91 octane. Can you get a bad tank of fuel from a tank labeled 91? Absolutely. Does one tank of bad fuel mean that every 91 octane pump in the country is putting out 85 octane fuel? Not even close.
    Summer fuel is different than winter fuel. I don't know how you can even come to a different conclusion based on the conversation that has occurred. Re-read your thread and see if you can figure out that you're trying to blend two separate-but-related discussions into one-single solution.
  10. RDgolfer
    My work was done here a while ago
  11. Dyn085
    I guess so.
    After all, your car is the one knocking and having to run higher octane fuel than the tune requires. There's not much need to listen to those of us that don't knock while running a higher-octane tune.
    Happy Turducken Day!
  12. RDgolfer
    I am sure that my car will be fine with Randy Robles at the helm...we are sorting it out..Oh, I just read that Justin at Freektune was dealing with the same issue with another FiST owner...I'm trying to be nice, but you are such hard case...let's be friends
  13. RDgolfer
    Timboslice and Firesail,Applejack,Dyno85,Razorlab, are not responding...
  14. RDgolfer
  15. Dyn085
    I'm sure you will be too.
    The issue you're talking about started at the very beginning of the custom tuning, not months after him purchasing the tune-there was no blame on winter fuels. After his tuning was complete I'm not aware of him having further problems, though I don't know if FL gets winter fuels. I can tell you read one single post that was posted today, but do you know any more of the history behind what you're speaking of?
    Here in NC, I do. There has been no knock in my car. I brought up that I was FreekTuned in the beginning so you would be aware-not to start a tuner war or try to discredit Randy. I've told you from my very first response to work with Randy to address the issue. If anything, you are the one trying to discredit him by constantly posting how you're knocking and forced to run higher octane than you're tuned for.
    You're clearly identified that you have a tune issue, and you keep driving that home with most all of your posts. If you are done tuning and you're still knocking then that's not good. If you're still in your custom tuning then let him work it. Don't make excuses for why you think a 91 octane tune should require 93 octane fuel, and stop trying to turn this into a Mountune/FreekTune debate.
  16. RDgolfer
    Go pick nothing boi....your song has been sung
  17. Dyn085
    Another logical respond.
  18. RDgolfer
    It's response you drunken moron! Edit!!!!
  19. RDgolfer
    Respond or response....idtiot
  20. RDgolfer
    Ok, no more nice..you don't know what you are talking about, yet you shit on people in here...what's up with you?
  21. Dyn085
    I'm glad to see you're learning, though you shouldn't need to resort to insults-especially in that glass house.
