Crickets anyone? (Engine sound)
Discussion in 'Fiesta ST Chat and Discussion' started by HardcoreFiSTing, Nov 7, 2014.
  1. Applejack
    Applejack Active Member
    That's the made up word i was looking for: symposer. Mine makes more nose with the intake now... Could have a leak?
    Maybe check all the hose clamps on all the charge tubes. They have been known to not be the tightest from the factory. They are made in Mexico... Just sayin!
  3. HardcoreFiSTing
    HardcoreFiSTing New Member
    I'll give it a look.
    I wonder if the drop in filter makes any change in sound. My wife loved the BOV type sound that a modded FoST we drove made. Wants her FiST to do the same.
  4. HardcoreFiSTing
    Watching some videos, I think it's just the way these cars sound.
  5. Applejack
    My wife just likes to roll her eyes at me and make a BOV sound.
  6. Applejack
    Most probable. If there was a real issue, a code would throw the engine light on.
  7. HardcoreFiSTing
    No engine lights. I did check the codes and I think the "NONE" as I cycle through and lack of a CEL indicates I have no codes.
  8. EcoBeast
    EcoBeast Member
    There is an immense discussion on cricket sounds in the FRS/BRZ forums. Over there it has to do with the fuel pump and certain grades of gas making the pump more/less noisy.
    I have not noticed anything on my FiST but the fuel pump maybe a potential source for the noise you are hearing.
  9. HardcoreFiSTing
    I actually saw the BRZ/FRS stuff when searching. I think it's nothing, until it loses power or outright breaks, screw it, it's under warranty.
  10. captainmorbid
    captainmorbid Active Member
    People are hearing it with the 1.0 ecoboost engine too, probably the DI fuel system. Like others have said, unless you get a dummy light or lose power or catch fire, I wouldn't worry.
  11. RDgolfer
    RDgolfer Active Member
    Fuel pump, loose clamps on charge pipes...possible...not that this applies, but I got my wheels balanced and aligned the car... and both were way out of spec...be warned, the car does not come out of Meheeko like a polished diamond
  12. RDgolfer
    Yeah, a definite FYI...get your ride, and check your ride...you paid for it, will pay for it, so you need to realize, no cares more about your Ford Fiesta ST than you do....trust nobody...be your own boss and stick to your guns if you have a warranty issue...trust your gut, ears, and eyes...I prefer to handle little things myself because the STealerships could make any problem worser...remember, the Stealership is not FORD! They are an independent entity...just saying...individual experiences may differ...whatever..
  13. HardcoreFiSTing
    I wouldn't be surprised if my alignment was out. This thing eats front tires at an insane rate for something that doesn't spend much time spinning them.
  14. Applejack
    Well, the threadwear on the stock tires is only 140. This evening i listened to my car in idle. Sounded like a few bushmen from "The Gods Must Be Crazy".
  15. HardcoreFiSTing
    I never bothered to look at the UTQG rating, but if these are 140 UTQG, they have to be the least grippy thing under 200 I've ever experienced..... They definitely wear fast for something with such an uncompetitive amount of grip.
  16. RDgolfer
    Again, your FiST is not coming to you perfect
