Daytime Running Lights
Discussion in 'Fiesta ST Chat and Discussion' started by chalituna, Jan 16, 2014.
  1. chalituna
    chalituna Member
    I guess I'll be the first guinea pig to try. It is a bit of expensive experiment..
  3. D1JL
    I positive you know this but remember to order the ones as used in Germany.
  4. chalituna
    chalituna Member
    Right. I actually requested LHD pattern from forpartsuk.com and they built a quote for me. However, something bothering me is if the headlight mounting point will be the same.. I hear it was an issue for previous model Fiesta
  5. D1JL
    That is just one of the points we are just not sure of.
    I honestly don't think this will be a problem.
    This is why we applaud your actions.
  6. chalituna
    chalituna Member
    lol. If it doesn't work, I hope they accept returns :dead:
  7. scooby2
    scooby2 New Member
    Thanks Dave!
  8. chalituna
    chalituna Member
    Dave, do you happen to know the part number for that relay you used when you wired up your fog as the drl?
  9. D1JL
    I am sure I do.
    I won't be home till late.
    I'll get back to you.
  10. D1JL
    Number I have is.
    F57B-14B192-AA
    chalituna likes this.
  11. chalituna
    chalituna Member
    Thanks Dave,
    This should be a big help once I get my headlights in and everything fitment wise goes smoothly.
    Did you plug it into the open relay slot right next to the fog relay?
  12. D1JL
    Yes I did.
    If you wait till this weekend I will post a photo along with the fuse tap.
  13. chalituna
    chalituna Member
    I'm thinking if it would be better if I just tap the wires for the DRL from other fuses that turn on when engine is running. Such as.. fuel pump?
  14. D1JL
    That is what I did.
    I will do the photo thing tomorrow and you will see.
    Entered using Dragon NaturallySpeaking.
  15. chalituna
    chalituna Member
    Thanks again Dave. My headlights actually arrived today but no one was home so they took it back... Now I have to wait til Monday :mad:
  16. D1JL
    That's great.
    Check the physical mount but I was thinking that even if the connector is the same the wiring may be different.
    Do you have or can you get the pin-out of the Euro connector?
    I have the pin-out for the US spec.
  17. chalituna
    chalituna Member
  18. D1JL
    Here is the photo as promised.
    By setting it up this way.
    I can remove the two relays (at R11 & R12) and the Fuse Tap.
    Replace with untapped Fog Light Relay at R11.
    And is then as if the mod never happened.
    Entered using my retro keyboard and mouse.
  19. chalituna
    chalituna Member
    I wonder what fuse rating i should use for the drl part? Perhaps a 25a?
  20. D1JL
    Can you get a copy of the Owner's Manual for the UK car?
    It should be in there.
    They are LEDs so it should be very high.
    I would think, no more than 10A.
  21. D1JL
    Could you pm me the headlight part numbers and prices?
