Direzza Z II's
Discussion in 'Fiesta ST Road Racing' started by Smokin, Feb 27, 2014.
  1. Smokin
    One of you track guys posted pix of the Dunlops after a track day and I can't find it. I asked what pressures you were running.
    Any help here?
  3. McRib 1s Back
    Hi there -- maybe my rig? Posted photos of my DZ2s. Check the Mountune spring thread. :)
  4. limbo
    For pressures - I run reverse of OEM specs. 36 front, 39 rear. (cold)
    After the tires get warm I may bleed off a little in front, depends if they're rolling over the shoulder and how much pressure they've gained.
  5. Zormecteon
    Have i been reading the specs wrong? I thought it was 39 front, 36 rear....?
  6. limbo
    No, you're correct. I found the reverse of the OEM specs to be a good starting point from a few auto-x events with these tires.
  7. RodMoe
    So the thought would be Higher air pressure in the back to help the car rotate?
  8. McRib 1s Back
    I don't have autox experience on these, but my 225/46/16s get hot on the track. I start 36/36 and gain 9-10 psi after a full session. More detail including photos in the Mountune Spring thread (started with camber then grew into tire wear).
    These probably are much better autox than road race style tires. In the "best track tires" thread, I'm leaning toward BFG R1.
  9. limbo
    Yes, exactly.
    Agreed on the application but they can still make decent track tires if you know their limitations. I've yet to see that much pressure gain with auto-x but I'm sure that tune will change when the summer events starting coming around.
  10. Slowclimb
    Definitely running higher pressure in the back will help the car rotate in Autocross. On my mini using dunlops I ran 40 - 42 Front 45 - 50 rear depending on the course. I plan on starting with the same sort of settings for the FiST too.
    The only care that I did not do this with was my miata, but I needed to do everything I could to keep the rear of that thing from coming around.
  11. spangenb
    Anybody (else) contemplating running the DZII as an everyday tire? How are they in the rain?
  12. limbo
    I was lazy after my last event and never swapped them out. That was a couple weeks ago, they're great in the rain. A little noisy but not unbearable.
    spangenb likes this.
  13. Slowclimb
    I will definitely run them as my summer tire... my star specs were great for every day use...until it gets cold.
  14. D1JL
    I too ran Direzzas and they were great for street use.
    In my area we don't get much rain (except this weekend) however I did manage to use them in the rain and found them to be very good.
  15. Nik17
    Nik17 Member
    I ran Z1s on my previous car and had no issue. I took them off when temps were regularly getting below 40*-45*.
    For the FiST I'm torn between the Z2s and Rivals though
  16. spangenb
    That decision is made already for me. I have 225/45-16 Direzzas awaiting the end of winter!
  17. Cligedy
    If you are considering the Rivals in 16" for autocross, don't do it. I got a look in my fender wells today after the test-n-tune last weekend. I knew that the tires rubbed, but it looks like they rubbed through part of the fender liner up front.
  18. Nik17
    Nik17 Member
    Interesting. I'm going for a 17" tire to put on the stock wheels for this season.
    I know the 215/45 Z2s fit, but am unsure about the Rivals so that in itself might mean I go with the Z2s. Do you know off hand what TireRack listed as the overall diameter for your size Rivals? I've heard they run big
  19. Cligedy
    24.9" i think.
  20. Nik17
    Nik17 Member
    Interesting. The Z2s that fit are 24.7". I wonder if they actually run big or if that 0.2" makes all of the difference
  21. Cligedy
    I thought the Rivals fit okay until I drove it hard. When the body leans in a hard corner, they rubbed pretty good.
