Do you have chassis questions?
Discussion in 'Fiesta ST Chassis Upgrades' started by WRC Fan, Aug 15, 2013.
  1. WRC Fan
    I'll be speaking with a Fiesta ST engineer next week. Do you have any specific chassis-related questions I might be able to ask?
  3. Removed
    I would like to know where the extra ~200 lbs of curb weight comes from vs. the regular Fiesta.
  4. Stevelach
    Stevelach Active Member
    I would like to know when I will get my chassis:)
  5. Removed
    That too!
  6. wash
    What are the differences in valving and spring rate between the b-spec coil over kit and a stock ST?
    What did you want to do to improve handling that you couldn't because of NVH, durability or fit issues?
  7. RodMoe
    Can I stuff a set of 225/45/17 Dunlap DZII Star spec's under it ??
  8. timo
    timo New Member
    For europe vs. usa ST....
    I weighed two identically equipped cars on the same scale, on the same day. Both full fuel...
    FoE = 2622 lbf, 62.5% front
    FNA = 2750 lbf, 60.1% front
    so 128 lbf different. Weight mostly comes from rear doors, bumper structures and other body reinforcements for US crash and full size spare
    Relative to base car....wheels/tires, brakes, body bits, turbo/ancillaries, heavier firewall liner (nvh), full size spare...all adds up
  9. wash
    I think he meant vs a non ST 1.6 Fiesta.
  10. timo
    timo New Member
    That's what the "Relative to the base car" bit at the end is for....
  11. RodMoe
    Did they have any insight on the biggest tire that can be fitted ? Only curious cuz I have a set of 17's waiting in the wings but will go with 16 if need be
  12. BRGT350
    215/40 17 is at the limit, actually at the point where there could be issues. There is a minium clearence that is required around the tire when the suspension is at its full range of travel. I plan on running 215/40 17 on my ST since I have ran them on my 2011 with the FRPP suspension without issues. I am hoping to test fit them on ST in October. As for smaller wheels, the smallest that will fit is a 15".
  13. Smokin
    Looks like the tires have to be under 24" in diameter? Checking out Tire Rack, the only stickies that may fit would be downsizing to 16" wheels and running Toyo Proxes R1R 225/45x16. They are 0.9" section width; 0.6" tread width and 0.2" dia larger than OEM 205/40/17.
    And they have white OZ rally wheels on sale! Wouldn't that look hot on an ST?!
    I would imagine BFG Rivals will have something by spring....
  14. Matt
    Matt New Member
    I would really like to hear more about their decision on the differential- did they test a real limited slip diff and if so what was the time difference around an autocross type course between a LSD and the solution they ended up with?
  15. RodMoe
    Yes what Matt Said !!! :mischievous:
  16. Smokin
    When you talk to the engineers ask if the stock suspension is equal to the FRP autocross suspension (for autocrossing purposes...)
  17. D1JL
    I would like to know the actual size of the ST's front Anti-Sway bar?
    Is it the same or larger then the non-ST?
  18. eRic
    according to the 2014 Fiesta ST supplement, the front stabilizer bar on the Fiesta ST is 19 mm diameter.
  19. D1JL
    Thanks,
    That is the same size as the non-ST front bar.
    I wonder if it is the same bar?
  20. RodMoe
    It could be the same as with FWD cars the rear wheels are the one you want to go up in size or add a sway bar to to get the car to rotate into the corner and not push .. Right ? So with the stiffer rear beam and different springs maybe the front was ok as it was .. Or I could be all wet here maybe BRGT350 can shed some light as he has both cars ..
  21. amathophobia
    amathophobia Member
    Stiffening up the rear on a fwd car helps reduce understeer.
