Escape Recall to affect Fiesta ST?
Discussion in 'Fiesta ST Chat and Discussion' started by mamiata1, Nov 26, 2013.
  1. mamiata1
    mamiata1 Active Member
  3. BRGT350
    I am pretty suire it will not, the recall is listed for a few months of Escape production in 2012. The same engine is used in the Fusion, and that is not listed for the recall.
  4. mamiata1
    OK but if you read the full article it mentions that one Fusion also had an engine fire. Hopefully the problem was fixed with the development of the Fiesta ST.
  5. BRGT350
    The Ford release says the following;
    "Ford Motor Company (Ford) is recalling certain model year 2013 Escape vehicles manufactured from October 5, 2011, through July 11, 2012, and equipped with a 1.6L engine subject to prior safety recall NHTSA 12V-336. In some cases, the engine compartment fuel line may have been installed incorrectly when repaired under the prior recall. The misinstalled fuel line could chafe and eventually leak fuel"
    This was from Autoblog earlier today. Nothing listed about the Fusion and says the recall is for Escapes that were recalled and fixed incorrectly.
  6. RodMoe
    And this about heads cracking but again only on the Escape they must have some weird plumbing in that Vehicle ...
    From NBC Detroit Bureau
  7. eRic
  8. mamiata1
    Let's hope we don't have to. Cracking cylinder heads? No thank you.
