Exhaust systems
Discussion in 'Fiesta ST Engine Upgrades' started by mrtn, Oct 23, 2013.
  1. graynicolas11
    graynicolas11 Active Member
    Agreed! Love how you can here the turbo spool too!
  3. stuntdoogie
    Jezzz!
  4. ST_Rocky
    ST_Rocky Member
    I had a Milltek on my R32 and loved it. Hope they bring one here soon.
  5. brian
    brian Member
    What's the diameter of the stock exhaust again?
  6. Removed
    2.2" IIRC.
    brian likes this.
  7. eRic
    ST-tuned 55 millimeters (2.17 inches)
    exhaust system with dual tips
    brian likes this.
  8. mcummings182
    mcummings182 Member
  9. Fistofthebrownstar
    Fistofthebrownstar New Member
    For turbo cars there is no backpressure tuning. The design goal is to get the heat out and away from the turbo as fast as possible.
    2.25 seems tiny to me. I'd be looking for 2.75 minimum for a 1.6L turbo. Larger than 3" probably has diminishing returns due to extra weight, unless you are upgrading to a much larger turbo.
  10. mrtn
    Makes sense, hence Cobb going with 3" for their exhaust. But why would ford go with 2.17" if they want to get the heat out quickly?
    I want to see what fswerks designs and hopefully mountune will get something out soon as well.
    I swear car companies purposely make things a little tuned down to make sure the aftermarket vendors stay in business.
  11. Fistofthebrownstar
    Ford doesn't want to get the heat out quickly. Ford wants a quiet, bulletproof, light, and CLEAN exhaust for what truly is a sporty version of an economy car. Part of making it clean means a restrictive Catalytic converter. Therfore, it makes no sense to make a larger free-flowing exhaust if the flow is getting choked off upstream by the Cat.
    EDIT: Car companies have more important design goals than just performance. Reliability, overall quality/comfort and fuel economy rank way above pure performance.
  12. mrtn
    So a 2.5" system would be a good compromise perhaps?
  13. Fistofthebrownstar
    I'm no expert, 2.5 might be sufficient
  14. brian
    brian Member
    For comparisons sake, when the neon srt4 came out, they had 2.25" exhausts with only a resonator in them (no additional muffler). They dyno'd around 210 wheel hp stock depending on year. The upgraded mopar performance exhaust (built by borla) was 2.5". Both exhausts were mandrel bent. The nsrt4 was a 2.4l engine, with a larger turbo than the ST, at a lower boost level.
    In my opinion, I'd think a 2.5" catback would be fine for a ST running a stock turbo. In my understanding of turbo systems, a 3" down pipe would be more beneficial as back pressure farther away from the turbo has less effect on performance.
  15. Smokin
    the mrt is too cummins diesel for my liking
    pelotonracer2 likes this.
  16. Smokin
    ill wait for the borla 2.5. 2.5" is just fine on my gti...and it has the 254 hp apr tune on it.
  17. mrtn
    Thank you!! I thought I was the one who didn't love it...
  18. stuntdoogie
    Full Milltek, De-Cat, Non-Resonated.
    Badass!
    ST_Rocky and moshaholic2 like this.
  19. stuntdoogie
    Milltek Exhaust Non Resonated Decat
  20. stuntdoogie
    Milltek Resonated
    Another Mill Non Res
    Man I just love the way this exhaust sounds!
  21. ST_Rocky
    ST_Rocky Member
    If the non res Milltek don't drone too bad inside the car while at highway speeds, this is EXACTLY the music I crave to hear! I loved the sound of my R32's VR6 with the resonated Milltek, and trust their ST versions will be just as top notch. Just when it it be available for us here? And how much?
