Fiesta ST TPMS reset/relearn procedures
Discussion in 'Fiesta ST Wheel and Tire Upgrades' started by Hiramw, Nov 19, 2013.
  1. mcummings182
    mcummings182 Member
    I took my car to my uncles friends house last night to get my snow tires put on, he has the tire changer machine. Unfortunately, I was unable to get it done because these tires are very hard to mount without completely scratching up the wheels. He said that his machine is cheap and unable to mount them without scratching up the wheels. Also he was afraid it would mess up something with the TPMS. So I'm going to a professional place to get it done after work. Will I have to follow those procedures to get the TPMS to work right?
  3. WScottCross
    If you're using the same rims, you only have to follow the rotation procedure that's described in the owner's manual. If you get new rims with new sensors, you need to retrain the vehicle to the new sensors as described here.
  4. mcummings182
    mcummings182 Member
    Oh ok, I won't have to worry about that until I get my spring/summer wheels mounted on the factory tires
  5. WScottCross
    Actually, If they do the tire swap one at a time and put the rims back on the same positions they are now, you won't need to do anything at all.
  6. audiphile
    audiphile Member
    no, you won't need to do anything.
  7. Smokin
    Come to think of it why doesn't someone make a handheld device that resets the vehicle sensor instead of the wheel sensor.
    That way I can have my rallycross and autocross wheels without TPMS like in the olden days...
  8. Noah
    Noah Member
    TPMS-19 (TPMS-19-8C2Z-1A203-A)
    Where do i get this?
    DOH.
    DIDNT READ.
  9. stuntdoogie
    LOL
  10. stuntdoogie
    When I turn my car on its says "tire pressure monitor fault" on the screen...tried doing these steps but no luck.
  11. stuntdoogie
    So the 6x hazard button starts the tpm procedure but my triggering tool and sensors are not syncing for some reason. Hope im doing it right by putting the tool near the stem and holding tje button till the red light goes off but nothing happens, isnt the horn suppose to honk after each wheel sync?
  12. audiphile
    audiphile Member
    6x hazard button is a different method. do the method described in this thread. Or come by to inwood and I'll try and do it for you.
  13. stuntdoogie
    Inwood in manhattan?
  14. audiphile
    audiphile Member
  15. stuntdoogie
    How long you gonna be up there?
  16. Zormecteon
    Be s
    Be sure to let us all know what worked. I've read that the "six times hazard" method it for rotating tires, not changing the rims completely. .. nothing but good reports from the "hit the brakes, on-offon.. hit the brakes.. off... on off on... method.
  17. stuntdoogie
    Cant get it to work with the above steps ugh...tried about 5x. Im starting to think sensors are fudged.
  18. stuntdoogie
    Update: Sensors synced thanks to Audiphile.
  19. Zormecteon
    what were the exact procedures
    pelotonracer2 likes this.
  20. pelotonracer2
    pelotonracer2 Active Member
    Yeah, let us know how you and Audiphile sorted it out.
  21. eRic
    the first post tells how to train new sensors vs. rotating the tires.
