Fuel levels for autox
Discussion in 'Fiesta ST Autocross' started by conevadr, May 30, 2014.
  1. conevadr
    conevadr New Member
    Just curious what others are doing...
    > minimum gas, minimum weight - any starvation issues?
    > full tank, better F/R weight balance and maybe keep the rear on the ground more?
    > half tank, compromise and more side to side weight transfer?
    Typically I run with around 1/4 to 1/8th, but haven't tried anything else. Thoughts?
    George M
  3. k757
    k757 Active Member
    I'm usually at 1/8 or less. Only had the low fuel light come on once. Never had any starvation issues (thanks Ford for good design)
    additional note, I reset the avg economy computer: 5.8 mpg YEA!
    Nik17 likes this.
  4. Cligedy
    At the match tour, my gas light came on during my first run. Between my co-driver and me, there were 8 runs total, and fuel starvation wasn't a problem. Weight balance is good, but weight loss is better. A gallon of gas weighs ~6lbs, so a half tank is ~40 lbs of sloshing ballast.
    k757 and spangenb like this.
