Green Filter Maintenance Question . . .
Discussion in 'Fiesta ST Maintenance' started by rcl4668, Jun 27, 2015.
  1. rcl4668
    rcl4668 Active Member
    I have the Mountune MP215 kit which comes with a reusable drop in panel Green Filter, a cotton filter similar to a K&N.
    Question on cleaning and reoiling this filter: I found a Green Filter video which explained that after cleaning the filter and air drying it, one applies the filter oil on just one said of the filter:
    From the looks of the video, it appears that the technician sprayed the oil on the "dirty" side of the filter that actually traps the dirt/particulates (i.e., the bottom side of the filter that faces down when installed in the airbox). Is that correct or does it not matter which side is sprayed? I am concerned about excess oil getting sucked into the engine. Thanks for your help!
  3. Etyrnus
    Etyrnus New Member
    That's the correct way to re-oil filters like these. Outside only for cone, or bottom for panel.
  4. rcl4668
    Thank you!
