Heater not working?
Discussion in 'Fiesta ST Maintenance' started by speedprotege, Jan 3, 2014.
  1. marc89gti
    marc89gti Active Member
    I have the part numbers from the service order, should be able to search on Fordparts.com
  3. WScottCross
    OK, I didn't notice the piece under the foam until i zoomed in. Mine is garaged at home, but sits outside while I'm at work and therefore I'll be asking to have mine done as well.
  4. marc89gti
    I did a Google search and the grill portion in the three pictures I attached showed the same thing as online pics. So now I'm not too sure what exactly the dealer installed. The installed 2 screens - part number D2BZ-18D395-A and 4 clips BE8Z-14197-A. Can't finds pics online though
  5. RodMoe
    Here are mine.. Car was built in 09/13 if that matters
    All Three vents have the grills
  6. Smokin
    I see no small strips...
  7. marc89gti
    Are you saying on your car you have no small strips below the foamy portion and basically have a big hole for where the air enters the car? My car was built 7/2013.
  8. btcca4
    btcca4 New Member
    Not sure how your dealer came up with those p/n's? The correct p/n is CE8Z-54020C16-A deflector kit. This kit contains 3 covers with clips & foam weatherstrips to seal off the cowl from the outside elements. The foam weatherstrip seals the cowl to the hood. No snow, ice, leaves or twigs can get into the ducts now.
  9. marc89gti
    Not sure about your part number, is there a TSB that refers to fixing the problem with the part number you have shown?
    The TSB my repair was done under is 13-11-17.
  10. marc89gti
    Can you take picture of this deflector kit you have had installed, curious to compare to what my dealer installed.
  11. LuvfiestaST
    LuvfiestaST Active Member
    Seems my car came with those 3 vents/sponges installed alreadyz..;))
  12. btcca4
    btcca4 New Member
    They look just like the deflectors Luvfiesta ST posted above. As far as I know, that is the correct TSB your car was repaired under. Confusing why 2 screens & 4 clips are billed out on the RO?? The parts manager showed me the box, in it were 3 shrouds with foam weatherstrip on them. They clip on over the existing screens on the cowl. Maybe the p/n is superseded?
  13. RodMoe
    So your car had NONE before this? I mean the foam vent shrouds
  14. marc89gti
    I do remember before taking my car to the dealer it definitely had the foam strip portion. But for some reason I thought my car didn't have the screen portion. I think my car was one of the earlier builds 7/13, so who knows maybe they started to add these screens in a few months later. The pictures I took after picking up my car from the dealer and posting in an earlier post also look like the pictures that Luvfiesta ST posted as well.
  15. reddog99
    FWIW, I just checked my car and the grill is wide open to everything. I can even look into the grill with the hood closed. Luckily, snow weather around here, even in the mountains, is sparse so I don't have much worry about. For reference, my build date is 9/2013.
  16. RodMoe
    Any chance of Pic's ??
  17. LuvfiestaST
    Some little fucker was texting on the line and skipped a few cars..))
  18. stuntdoogie
    Took a pic of mine. Could you tell me if mine has that strip you talk about cause ai have no clue what you are talking about.
  19. marc89gti
    You have the small strips or grill portion below the foam for the three air intakes. I have seen some pictures online of Fiesta St's where they didn't have the foam portion on the air intakes. Perhaps the first 3-4 months of production was missing the foam and strips or grill portion.
  20. marc89gti
  21. RodMoe
    Weird how even on that site some have and some don't !!
