HID Kits
Discussion in 'Fiesta ST Exterior Upgrades' started by OxWhiteFiST92, Nov 24, 2013.
  1. pelotonracer2
    pelotonracer2 Active Member
    So I could use the same $65.00 Sylvania Ultra ZXE bulbs in the driving lights too? lol
  3. McRib 1s Back
    Did you try it yet? I think that could be a nice setup. They're plenty low, but maybe lack enough diffusion?
    pelotonracer2 likes this.
  4. pelotonracer2
    I haven't done the fog/drivers bulbs yet. I swapped the headlight low beams out a few days ago. I really like them a lot better than the stock bulbs. I still need to replace the driving /fog bulbs so they match.
  5. OxWhiteFiST92
    OxWhiteFiST92 Member
    Can we get a pic when you're finished? :D
  6. pelotonracer2
    Absolutely. :)
  7. pelotonracer2
    Speaking of which, do the fog light assemblies just pop out and or how are they held in? I haven't looked at mine yet. The headlight assemblies are so easy to remove on this car. Took me all of 10 minutes to replace my low beam bulbs.
  8. Removed
    Ford recommends removing the headlight assemblies to access the fog lights, but I'm pretty sure if you lift the car you can access them from underneath too.
  9. pelotonracer2
    Cool, thanks. I'll have to take a look later today.
  10. badmoonkid24
    badmoonkid24 Member
    I just got my hid fiesta kit
    Sent from my SGH-T999 using Tapatalk
  11. Tim McCarthy
    Tim McCarthy Member
    So. Much. Glare.
    Sent from my XT1034 using Tapatalk
    TWDM, RKTFiST, joker96 and 2 others like this.
  12. LuvfiestaST
    LuvfiestaST Active Member
  13. LuvfiestaST
    Looking to replace the oem bulbs in the st headlights.. Any suggestions??
  14. badmoonkid24
    badmoonkid24 Member
    Go hid's
  15. LuvfiestaST
    What's a good HID conversion kit.. I'm in Toronto Canada..
  16. badmoonkid24
    badmoonkid24 Member
    SoCal accessories.com or call em 9098159402 ask for the Ford Fiesta HID kit you want 5000 on top and 3000 on the bottom Calvin tell him its the same kit you want the same kit robert got on his fiesta
  17. moshaholic2
    Has anyone figured out yet the jumper wire mod like on the MK1 Focus?(all lights on at once, highs/lows/fogs)
  18. badmoonkid24
    badmoonkid24 Member
    Easy installation hid's
  19. D1JL
    The car does not have low beam relays and because of the switch configuration along with the BCM, it would be best to use diodes at the headlight connectors.
    This way you could turn the lows or fogs or both normally.
    When you turn on the highs you would get all three.
    I have worked out the instruction for this with pin numbers and wire colors.
    If you would like I could post this.
  20. chalituna
    chalituna Member
  21. LuvfiestaST
    Went to get HID kit today but was told they probably won't work on my car.. Hmmm
