HID Kits
Discussion in 'Fiesta ST Exterior Upgrades' started by OxWhiteFiST92, Nov 24, 2013.
  1. badmoonkid24
    badmoonkid24 Member
    Just call SoCal accessories at 909 815 9402 ask for the Fiesta ST HID kit its plug n play it's not rocket science give Jason a call
    Sent from my SGH-T999 using Tapatalk
  3. badmoonkid24
    badmoonkid24 Member
  4. LuvfiestaST
    LuvfiestaST Active Member
    I assuming they are in The States?
  5. LuvfiestaST
    Are they 5000k or 6000k?
  6. LuvfiestaST
    I prefer to buy local just in case I have any issues
  7. LuvfiestaST
    Hey guys I was wondering if any of you guys who knows the wiring and changing of the fog lights/headlights on this car can answer a question(s). Be much appreciated..
  8. badmoonkid24
    badmoonkid24 Member
    In ca top is 5000 & bottom are 6000
  9. badmoonkid24
    badmoonkid24 Member
    3000 on bottom
  10. D1JL
    As requested.
    And revised
    Fog lights can be turned on alone.
    Fog lights can be turned on with low beams.
    However when high beams are turned on fog lights are not.
    This modification will allow the low beam and fog lights to work normally.
    In addition the high beams will also turn on the fog lights.
    This may not be legal in some states.
    On either the right or left headlight connectors.
    Connect the anode of a diode to the high beam wire at pin #4.
    On the left side this wire is White.
    On the right side this wire is Gray/Brown.
    Connect the cathode of the diode to pin #1 of an added relay.
    Just buy a Ford relay just like the current fog light relay.
    You can use terminal connectors but it fits better if you just solder wires to the inside of the relay.
    This way everything fits in the relay/fuse block next to the battery.
    Remove the relay's plastic cover, it just pops off.
    Connect wires to terminals #1, #2, #3, & #5.
    If you connect to the inside of this relay you can drill a hole in the plastic top and run the wires out the top.
    This will allow you to place the relay into an unused socket with no connections.
    The relay will just sit there and the box cover will keep it from jumping out.
    On the new relay, connect terminal #1 to the cathode of the diode added above.
    Connect terminal #2 to #5 and connect these to ground.
    Connect terminal #3 to terminal #2 of the car's fog light relay.
    The new relay will energize when the high beams are turned on.
    It in turn will energize the fog light relay.
    The fog light switch will continue to function normally.
  11. F1ST
    F1ST Member
    Thanks for the info. Do you have the wiring color for low beams to do low to high?
    How much current do you think the high beam circuit can handle? Will the added 55w / side be too much?
  12. D1JL
    The low beams are already on when the high beams are added except in flash.
  13. D1JL
    I just revised the modification.
    This should address any current issues.
  14. TWDM
    TWDM Member
    Getting my morimoto mini H1s installed while I'm gone on vacation. Will post pics when I get back.
    Tim McCarthy likes this.
  15. LuvfiestaST
    Has anybody change the fog light bulbs and if so what was the easiest way to do it?
  16. F1ST
    F1ST Member
    Easy, pull the headlight.
    Remove the two torx screws and one panel fastener. To remove panel fastener try unscrewing the center till it is about 3/8" up or all the way out then lift the whole thing out. It may not unscrew and come up so you may have to lift up underneath the center portion with a flathead while unscrewing. The center expands the outer part under the two connected parts to hold them together.
    Disconnect the headlamp wiring connector.
    Pull up on the headlamp housing, it is clipped in on the bottom with a spring clip.
    Look down and the fog is right in front of you.
    Twist the bulb/socket to pull it out. I found disconnecting the fog connector first was easier, just push on the tab.
  17. LuvfiestaST
    I got the two bolts out but I couldn't get the clip and I was afraid of breaking the headlight
  18. F1ST
    F1ST Member
    Updated to try and explain the panel fastener removal.
  19. LuvfiestaST
    Kewl thanks for the info...
  20. LuvfiestaST
    Are those yellow hid fogs you installed?
  21. F1ST
    F1ST Member
    I just installed regular H11 yellow 2500k bulbs.
    Rellik1 likes this.
