HID Kits
Discussion in 'Fiesta ST Exterior Upgrades' started by OxWhiteFiST92, Nov 24, 2013.
  1. LuvfiestaST
    LuvfiestaST Active Member
    Changing my fogs on Sat but been reading several ways to do it. Neither one seems easy to do in the winter
  3. D1JL
    By far the easiest way is to remove the headlights and just reach in.
    The best way in the winter is to warm up the car first.
    Sent by fingering my phone.
  4. LuvfiestaST
    Why warm up the car first??
  5. D1JL
    I assumed you were cold..
    Nothing you are working on gets hot.
    Warm car radiates heat.
    Keeps you warm.
  6. LuvfiestaST
    Lol I can handle the cold. It's in the Newfie blood..it's the salt and slush that covers my car..;((
  7. WScottCross
    If you're pulling the headlights, it probably is best to warm things up. The headlight clips under the edge of the bumper cover and it's a tight fit. You could crack the cover if you try to pull the headlight when it's really cold.
  8. D1JL
    Yeah,
    There is that too.
    I don't have too much of that here.
  9. RodMoe
    Oh I enjoy after you think you have it thawed out and you put it on the jack and as you slide under it that last drop of salty slime water drips down into your ear !! :meh:
  10. LuvfiestaST
    I found whenever I work on a ford car there is always that one screw that gives me trouble..why do they use plastic screws to hold things together? Can't they use regular bolts like the other 2 they used and not plastic clips
  11. LuvfiestaST
    Well new HID foglights are in.. Boy what a pain but looks good
  12. D1JL
    There is no actual support needed at that point.
    They are just filling a hole. :)
    Entered using Dragon NaturallySpeaking.
  13. LuvfiestaST
    New HID yellow fogs.. Sorry bout the glare
  14. D1JL
    I too have used Yellow Fog Blubs.
    I went with PIAA 2500K.
  15. badmoonkid24
    badmoonkid24 Member
    Sent from my SGH-T999 using Tapatalk
  16. LuvfiestaST
    Which is better PIAA a or silver stars?
  17. D1JL
    It is just a brand choice.
    I have had very good luck with both.
    In this case I wanted a very yellow light.
    Of the top brands only the PIAA had 2500K.
    Maybe I didn't look hard enough.
  18. TWDM
    TWDM Member
    Turns out our headlight are permasealed. Have to find someone willing to cut them open to retrofit it...
  19. mossdahaus
    mossdahaus Member
    ZXE bulbs (low/high/fog) with stealth amber 3157 bulbs. Definitely cleans up the front!
  20. TWDM
    TWDM Member
    Here's a few pics of my hids so far. Will post pics at night later 20140211_124042.jpg 20140211_144210.jpg
    Tim McCarthy likes this.
  21. Tim McCarthy
    Tim McCarthy Member
    That's the right way to have HID's. Which projectors/shrouds did you go with?
