Hooking up a sub/amp.
Discussion in 'Fiesta ST Interior Upgrades' started by Nendez420, Jun 12, 2014.
  1. Nendez420
    Nendez420 New Member
    Anyone have any instruction on the wiring I need to lead into my amp from the head unit?
    http://www.amazon.com/Rockford-Fosgate-R2S-1X10-10-Inch-Enclosure/dp/B0068XYNH4
    http://www.amazon.com/PAC-SNI35-Adj...ywords=line+out+converter+with+remote+turn+on
    http://www.amazon.com/KIT-2-Complete-Gauge-Amplifier-Installation/dp/B000FKP7TY/ref=pd_bxgy_e_text_y
    Already have a 1000 watt amp, going for the under floor above the tire setup. What's the easiest location to hook the converter up too? And is there anything I'm over looking?
  3. Nendez420
  4. bduane
    bduane New Member
    The remote wire was the easiest part of my install so far. Tapped into the fuse box and ran it under the weather seal for the doors under the rear seat into the trunk, took about 5 min.
    I'm still trying to figure out the best place to tap into the speakers for input. I see others only tapping into 1 channel, but I'd like to tap into both as my amp has inputs for both right and left and I assume it combines them into the mono output to the sub. I'd also like to mount the loc somewhere where it is fairly easily accessible for tuning.
