Instrument Panel Test Mode
Discussion in 'Fiesta ST Chat and Discussion' started by F1ST, Jan 25, 2014.
  1. F1ST
    F1ST Member
    Tried the test mode on the FiST today. Works similar to my previous 2011 Fiesta SE.
    Hold the reset button on the tach before starting the car. Continue to hold until it enters test mode.
    I hit the button about every 3 seconds or so.
    Not sure what everything does, only just tried it. Some are easy to figure out, tach, engine temp etc. Maybe we can get a list going of the 'pages' it cycles through. Would be nice to see if there is a MAP sensor readout. Let me know if you figure out any of them and I'll update the list. Could probably see if there is list of previous year Fiestas and figure some out that way too.
    01. Needle Sweep test
    02. VFD display test
    03. LED test, all on
    04. LED test, all off ?
    05. LED ? (Will try when dark maybe I'll see something different)
    06. Warning chime test
    07. rAN ?
    08. Er 1001 ?
    09. E 01 ?
    10. r8C ?
    11. dtSt 70 ?
    12. dt410E ?
    13. none ?
    14. Speed, MPH
    15. Speed, KM/H
    16. 590064 ?
    17. Tachometer RPM
    18. t90xxx ?
    20. od000 ?
    21. F 0175 ?
    22. F90282 ?
    23. FL xx ?
    24. FP 3A ?
    25. Coolant Temp
    26. bt xxx ?
    27. Distance Till Empty, km
    28. rAF08.3 l/100KM Fuel Consumption?
    29. A0-xxx ?
    30. A1-000 ?
    31. A2-xxx ?
    32. A3-xxx ?
    33. 44-xxx ?
    34. A5-xxx ?
    35. P01- xx ?
    36. P02- xx ?
    37. P03- xx ?
    38. P04- xx ?
    39. P05- xx ?
    40. P10- xx ?
    41. P11- xx ?
    42. P13- xx ?
    43. P19- xx ?
    44. P20- xx ?
    45. 00
    46. 19r -.-
    47. 1Pr -.-
    48. 1h5 -0-
    49. --- -.-
    Sekred and LotusZX3 like this.
  3. CarefreeAZ
    CarefreeAZ Active Member
    I just used this today on my SES (my 2011 does not have a temp gauge so I sometimes start it in test mode to check coolant temp, in C* rather than F*). I was going to check it out on the ST to see if there was a boost readout.
  4. mossdahaus
    mossdahaus Member
