Lighting upgrades
Discussion in 'Fiesta ST Interior Upgrades' started by spangenb, Dec 31, 2013.
  1. BRGT350
  3. LuvfiestaST
    LuvfiestaST Active Member
    Can I use led's in the fog lights.. I NEED bright lights, I find at nite the factory bulbs are the shits
  4. silvertoy
    silvertoy Member
    YES! someone else who buys from Rallylights.com :) I've been to their "store" several times as it's about 30 minutes away from here (Allentown). I have bought so much from them for my Jeep over the years. I was thinking about getting some of the dichroitic bulbs for the highs -for $7, I can afford to not like them, however, I usually find that's not the case with Hellas.
  5. F1ST
    F1ST Member
    I'm the other way. I actually want a more yellow look.
    Does anyone have a recommendation for that ? I just don't get the super white or purple look.
  6. silvertoy
    silvertoy Member
    This is what I'm doing for the fogs. I ordered the Hella optilux yellow H11 bulbs for the fogs. But I've had good luck with the ZXEs in the past so I went with those for the H11 Low and H1 High. have some Hella Diacromic H1s coming to compare as well.
  7. F1ST
    F1ST Member
    Ordered some yellow H11 fog bulbs and put them in today.
    Daylight comparison
    Night comparison
    From inside
    Both, fog only
    Both with headlamps
    EcoBeast, LuvfiestaST and Firesail like this.
  8. LuvfiestaST
    Just picked up hid yellow fogs lights.. Now to install them
  9. LuvfiestaST
    Has anyone taken out the glove compartment light?
  10. 70sstrat08
    70sstrat08 Member
    Just wanted to chime on interior lights. I did mine today using the DIY on our sister site. Only thing I have to add is when you pull down the front dome, if you have a sunroof, reach from the windshield side and pull the big "fuzzy" plug toward the windshield to give you more slack. I thought it would just pull down with the assembly and broke the little retainer that holds the black white and yellow wires.
  11. Ryan Owens
    Ryan Owens Guest
