Manual Transmission Fluid: Motul 300 Gear oil! (handy spec chart too)
Discussion in 'Fiesta ST Maintenance' started by McRib 1s Back, Mar 26, 2014.
  1. McRib 1s Back
    In preparation for my next track day at Big Willow, I decided to switch out the manual transmission fluid for something slicker: Motul 300 75w90!
    I've been impressed with all Motul fluids in the past, so I figured this wasn't much of a gamble. This in conjunction with my new short shifter should help me select the right gear at speed! :)
    Only about 1.5 quarts drains out; note that the manual calls for 1.8 quarts (or 1.7 liters).
    I found a handy PDF online and have clipped a section here for reference:
    Jaytech likes this.
  3. smatty
    smatty Member
    Which short shifter did you go with?
  4. BlueBomber
    BlueBomber Active Member
    Let me know how this feels because i am a motul distributor; might make a great How-To!
    In addition, I can make it available as a service for anyone not wanting to do it themselves.
    Jaytech likes this.
  5. McRib 1s Back
  6. Firesail
    Is there another besides mountune?
  7. McRib 1s Back
    I think feedback from the track will be telling. A couple weekends ago I missed third a couple times. It was odd, it's the only time I've done that in the FiST (road or track). I might have been a bit lazy and really started to focus on that 2-3 shift, and it didn't happen again. Like we were discussing in the other thread, the throw was a bit long. Maybe this is a big upgrade! :)
  8. McRib 1s Back
    I think 2J Racing is coming out with one (and believe a couple people are testing it now). It's a pretty simple solution. The craftsmanship for the Mountune part is very nice.
  9. McRib 1s Back
    For street driving, I can already tell it's a nice change. The engagement is more precise, and the throw is modestly shorter. Most importantly, it didn't create a weird notchy feeling. It glides home into third, and I think the fluid gets some credit here. I did both at once, of course.
    I've only driven several miles while bedding my new brake pads.
  10. hyatt
    hyatt Active Member
    Is there any aftermarket trans oil that meets Ford's spec for these cars? It's weird that they specify a dual clutch fluid...
  11. RodMoe
    Royal Purple says their Synchromax Does data Sheet linky
    They (Ford) used the same fluid in the 6 spd manual transmission Mustang in 2011 not sure if they still do or not..
    I tried the RedLine Stuff at the time and it didn't do much better shifting wise..
    Now the RedLine site not even listing anything for the FiST ( and this is what they say about the Mustang 6 spd Manual)
    ronnie karlen likes this.
  12. hyatt
    hyatt Active Member
    Interesting. I looked to see if Redline had anything comparable to the Synchromax but came up with nothing.
  13. wash
    A friend of mine swears by Amsoil for gearboxes.
    I don't know if they have anything approved but its another place to look.
  14. RodMoe
    AMSOIL is Great if you can find it but this is what their online list says
    Weird they list no motor oil yet either
  15. wash
    I'm starting to wonder if the transmission was designed to work with the dual clutch fluid or to work despite it.
    According to Wikipedia:
    The Ford dual clutch transmissions have mostly used wet clutches which means the oil probably has some friction modifier in it like the gear oil you use in a clutch type positraction diff.
    Since we have an electronic (open) diff and a dry clutch, the dual clutch oil might just be what they want to put in everything or maybe everything Getrag.
    Any way, I think dual clutch oil is a weird choice...
  16. captainmorbid
    captainmorbid Active Member
    The fiesta DCT is dry clutch, not sure about the focus.
  17. wash
    Yeah, but the same oil...
  18. RodMoe
  19. captainmorbid
    Dry clutches have character...
  20. McRib 1s Back
    Didn't you mean "...have chatter"? I hate that sound on a Ducati. :)
    captainmorbid likes this.
  21. McRib 1s Back
    This setup was a very nice change at Big Willow. It basically made gear shifting a non-event. It's shorter throwing, slicker shifting, and worked without any issues. This is a very easy recommendation -- it's cheap and easy! Do it.
    Also, when you re-install the shifter cable, make sure it's firmly seated on top. I heard they can pop off. It hasn't happened to me, but I've heard it can happen. If it happens, I heard you can pop it back on again in like two minutes. ;)
