Mini Cooper wheels (or similar aftermarket) fit on Fiesta ST?
Discussion in 'Fiesta ST Wheel and Tire Upgrades' started by ColoKevin, Oct 10, 2013.
  1. ColoKevin
    ColoKevin New Member
    I think the Mini Cooper S wheels are 17" X 7". Anyone know if the offset/backspacing/lug pattern are the same?
  3. EvoNiner
    EvoNiner Active Member
    What year? They have different sizes for different years. The 03's aka the older generation I believe is a 4 x 100. We need 4 x 108
  4. Sil3nt611
    Not a lot of cars use the 4x108 pattern. The Mini uses 4x100 which is a lot more common. I just did a search to see what cars did come with it. It seems to be more of a European size. In the US the most common cars to have this size seem to be the Focus, Fiesta, and Contour. There's a handful more European cars that have them. Your bet bet is aftermarket.
  5. wash
    It might be possible to retrofit Mazda 2 hubs or re-drill the Fiesta hubs for a 4*100 lug pattern but you would have to drill your brake rotors too which could be an issue when you need a replacement.
  6. Ataru
    Ataru Member
    If the rotors are still floating rotors then the hub would keep them centered and you could just enlarge the lug holes some for the clearance on the rotors.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
  7. AlanBDahl
    Audis use 4x108, my '95 90 Quattro Sport had 15x7 4x108 wheels. I found some double-drilled 4x100 / 4x108 wheels which was a good solution as they also fit my Miata.
