mountune quick shift to be installed by dealer - will they add different bushings for me, too?
Discussion in 'Fiesta ST Engine Upgrades' started by TapTapPull, Dec 11, 2014.
  1. TapTapPull
    TapTapPull Active Member
    I have the quick shift on the way from mountune, and will have it installed by the dealer to keep the warranty intact.
    I've also ordered the boomba racing shift cable bracket bushings as well as their shifter base bushings.
    While reviewing install guides for these products, I see that the pieces that need to be removed to install the quick shift kit and the cable bracket bushings are basically the same.
    Do you think if I dropped the bushings off with the quick shift kit, the techs would install both at the same time?
    May be a silly question, and I am totally prepared to remove everything a second time to install the cable bracket bushings myself, but if Ford would do it, it would save me more time/risk.
  3. Firesail
    I installed the intake kit and quick shift myself in mine. My dealer happens to be mod friendly. I would install the bushings myself and pocket the difference.
