My dead pedal solution
Discussion in 'Fiesta ST Interior Upgrades' started by The Duke, Jun 25, 2014.
  1. The Duke
    The Duke Member
    So, I wasn't satisfied with the dead pedal (well, lack of stock) in the ST, and all the aftermarkets require drilling and don't match anyways. Well, we had a similar situation with the STi, and a company called Subtle Solutions CNC an aluminum replacement with rubber grips that matches the OEM STi metal/rubber pedals exactly. Turns out it matches out pedals close enough.
    http://www.subtle-solutions.com/product_info.php?cPath=21_24_27_38&products_id=127
    The OEM STi pedal is held in with two push-pin retainers that fit into pre-existing holes. Well, when Subtle sends you the pedal, they send you a few replacement rubber pieces if/when they fall off from use. Luckily i had my large rubber piece left over from the STi, so I used that with the spare they sent with the new pedal to cover the holes for the mount. Perfect;
    To secure it I used a long strip of hook side velcro to catch the fibers of the OEM Fiesta carpet. I covered the entire backing as I didn't want dirt to get stuck there and there's less chance it'll come off during something like autocross, or just general use.
    Then it's a simple stick-on operation. It can be pulled off easily and shouldn't damage the underlying carpet. Besides, it's nearly the exact size of the "dead pedal" area Ford left us.
    Is it perfect? No, but it's close enough, and mimics some of the details found on the brake and clutch pedal (the rubber dimpling). Besides, it grips well, protects the carpet, and likely won't hurt the carpet.
    Flaco1 and envyist like this.
  3. mrtn
    Looks pretty good. Does match the pedals!
    Here's mine. A guy on fiestast forums makes them. I added the red to the logo though. No drilling. I used Velcro to attach it sticks really well.
    no-pistons likes this.
  4. mcummings182
    mcummings182 Member
    Would that user be no-pistons?
  5. mrtn
    Correct.
  6. MLKN
    MLKN Active Member
    Is he selling them? How can I get one?
  7. Removed
    Ditto
  8. mrtn
    He is selling them. There is a thread on fiestastforum.org and I just messaged him. Pay through paypal, but he makes them in batches so it's not like they are readily stocked. Price is $40 shipped I think. Unless he upped the cost by now...
  9. WScottCross
    I'm in for that.
  10. envyist
    envyist New Member
  11. mrtn
    Thank you. I tried to put up the link but it was not working through tapatalk
