MyFordTouch hacks, mods, updates, etc.
Discussion in 'Fiesta ST Interior Upgrades' started by nummypuppies, Dec 8, 2013.
  1. WestcoastST
    WestcoastST Active Member
    Per Tascaparts.com here are the part numbers for the camera and bracket:
    Camera: D2BZ-19G490-A $86.48
    Bracket: D2BZ-19H421-A $15.47
    Emblem: D2BZ-19H421-A $14.08
    Kevin R likes this.
  3. D1JL
    What about the module and harness ?
  4. WestcoastST
    I would think one would use lockpick, in order to allow the NAV unit to show the backup camera. Otherwise, dirtyblueshirt showed his Fiesta titanium rear view camera setup, which included the harness. I still do not think it would be plug and play, even with the harness, but could be wrong. Both methods I've seen (lockpick and NAV-TV) require a hardware box to program the MFT system. I'm looking for an OEM look, but also being able to use the rear view camera per lockpick (which is less expensive than NAV-TV).
  5. Kevin R
    Kevin R Member
    Has anyone confirmed one way or the other if the North American ST's have a wire for the camera already in place? If so, the factory camera and Lockpick would be a fairly easy install. If not, the biggest problem would be feeding the wire all the way from the hatch to the Lockpick.
  6. RodMoe
    I did it on my full size Dodge Challenger and it only takes time and a little or lot of patience to take the inner body panels off and feed the wire around the hatch/trunk area along the center hump to the consol and you are home.. but as I found out that is easier said than done sometimes ..
  7. moff3tt
    moff3tt Active Member
    Can't be worse than feeding anything through the tunnel of an air-cooled beetle. Or even installing a wiring harness in a cabriolet. Haha, those were not fun times in my life. Hopefully someone takes the plunge and lets us know.
    Edit: http://www.tascaparts.com/oe-ford/d2bz14a005c?search_str=D2BZ-14A005-C this is the wiring harness that goes to the hatch. Apparently it is the same for all Fiestas.
  8. aar0n
    aar0n Member
  9. moff3tt
    Dude that is so sweet. Maybe we can get the performance suite like Civic Si's get and perhaps the ability to add a g-force sensor and other cool bits!
    aar0n likes this.
  10. rushinge
    rushinge New Member
    I've never been able to display song and artist information from Pandora on my 2015 FiST with my 2014 Moto X.
  11. Izzy
    Izzy Member
    What he said!! I even have the map sd card!
