Need help wiring amp to stereo...
Discussion in 'Fiesta ST Maintenance' started by Tom Brooks, Mar 12, 2014.
  1. Tom Brooks
    Tom Brooks Member
    Has anyone removed the stereo yet or found out which plastic to remove on dash to get behind system. I need to hunt for that troublesome green remote wire for a new amp I'm going to install. I don't even want to think the thought of me snapping plastic clips and fasteners as I try to get behind this thing...
    A follow up question is has anyone found the plug or a hole in the firewall to run the hot wire for an amp inside the car? I'm nervous about pealing up carpet as well.
  3. Parker
    Parker Member
    Did you ever figure this out? I just did it on mine and can help you if you still need.
  4. stuntdoogie
    Would love a brief tutorial on how to install a sub amp if possible...
  5. Parker
    Parker Member
    ok I'll try to do that today and I'll post a video
  6. stuntdoogie
  7. Parker
    Parker Member
    Alright here she is, let me know if you have any other questions!
  8. Tom Brooks
    Tom Brooks Member
    Thanks so much man! This was very helpful!
    Parker likes this.
  9. wash
    Could you show where the power wire comes out in the engine compartment?
  10. D1JL
    Mine is wired almost exactly the same as Tom's above.
    I used the power to the antenna to be the remote trigger for the sub amp.
    This is a black wire in connector C212 pin 10 located in the right kick panel.
  11. Parker
    Parker Member
    here you go -
  12. wash
  13. aar0n
    aar0n Member
    Thanks alot for the video documentation.
    I couldnt sell my mtx 8000 so i guess I might put it into the fiesta and just buy a cheap amp to hookup lol. I doubt you need alot of power inside this tiny car.
