New MountuneUS Parts Coming
Discussion in 'Fiesta ST Chat and Discussion' started by CarefreeAZ, Sep 5, 2013.
  1. CarefreeAZ
    CarefreeAZ Active Member
    Received an email from Ken Anderson this afternoon that said, in part "...will have floor mats, shift boots and many other products as we move forward. We are also producing a new front spoiler extension (see below)...not sure the winglets will fit the ST as the spoiler is slightly different."
    Can BRGt350 or anyone with an ST and access to a Euro-spoiler equipped non-ST confirm spoiler difference?
    MOUNTUNE Fiesta ST Front Spoiler Extension
    bryramos likes this.
  3. MGORDON
    MGORDON New Member
    To that end, anybody have any experience with their quick-shift kit for the ST?
  4. D1JL
    I have a Euro Spoiler with the "Winglets" on it that I am keeping from my current 2011 Fiesta.
    From all that I can see, they look the same but I am unable to be 100% sure until I get my ST in about 10 days.
    As I am unable to remove the "Winglets", my plan was to just fit the entire Euro Spoiler.
    I am sure the hatch itself is the same.
    Since I live just above L.A., I could just make an easy drive down to Mountune.
  5. RodMoe
    I see they went live with the US website.. not sure it is allowed here but its their name "mountune" with a usa at the end then a dot com. nothing much there yet but a short shift and a FMIC
  6. Removed
    That front extension looks snazzy. Short shift kit too.
  7. BRGT350
    I am 99.999999% sure the ST rear spoiler and European spoiler from the Ford Accessories are the same. I would see no reason to develop a spoiler that is different. That would mean the rear Mountune extensions will work. There sure isn't a lot of difference between stock and the Mountune front spoiler thingie. It does bring the surface in front of the intercooler out to the rest of the bumper, so that is nice.
    I do have some pictures of both the ST with my 2011 Fiesta, but have not posted any of them yet.
  8. CarefreeAZ
    Thanks Bryan. That's what I thought too.
  9. Removed
    It's subtle but I like that. I hope they offer them paint-matched.
  10. Fiat slayer
    Fiat slayer Member
    rallysport direct has the shifter for $249
  11. spangenb
    MGORDON, I installed the Mountune quick shift kit (bought from FSWerks) a couple of weeks ago. It was definitely a bit of a pain to install. You have to tighten three Allen-head bolts and there is very little room in there. That was a minor inconvenience and once installed it makes the shift throw exactly right in my opinion. The factory shift throw was too long and the feel too light. This kit fixes both issues. I did have an interference issue that I described to FSWerks with pics and suggested they pass on to Mountune: I drove the car post-install and immediately noticed it didn't completely go into 6th gear. I wondered if there was any cable adjustment and went to bed. The next day I had time to look at it and discovered that in 6th gear the two shift levers on the transmission are nearest each other. The transverse gate lever (I don't know the right word, but the lever that moves you from the 1-2 gate to the 3-4 gate, etc.) was running into the nylon rod end for the main lever. The Mountune adapter moves the ball attachment for the cable closer to the pivot and also closer to the other lever. I was able to get some pry bars in there and bend the lever over about 1/8 inch. Now it's all good, but Mountune definitely made the design a little tight to deal with car manufacturing tolerances.
  12. RodMoe
    Which way did you get the lever to bend ? Towards the battery or away ? Thanks for sharing...
  13. Sekred
    Sekred Active Member
    Hi Rod, if you choose this option to correct the problem, see image
  14. RodMoe
    Awesome Pic Thanks :)
  15. spangenb
    Yup Sekred that's the same pic I took :) It's hard to get leverage, but it just needs to bend slightly toward the battery.
    Sent from my SCH-I545 using Tapatalk
  16. Sekred
    Suggestions for new short shift kit.
    Firesail, spangenb and RodMoe like this.
