Offset vs. backspacing
Discussion in 'Fiesta ST Wheel and Tire Upgrades' started by Smokin, Jul 17, 2014.
  1. Smokin
    Help me figure this out. What's the difference between offset and backspacing? Which number moves the wheel/tire in or out from the strut?
  3. iLiptiKal
    iLiptiKal Active Member
  4. IIRC, et is the positive (toward the outside) or negative distance from the C/L of the wheel's rim to the flange face of the wheel's spider. Back space is the measurement from the back lip of the rim to the flange face of the wheel's spider. Back space is typically a positive number, et can be a positive or negative number.
    MH
  5. Dyn085
    Dyn085 Active Member
  6. jimclark
    The video was pretty clear, and helped assure me that I was correct in assessing the inside v. the outside of the wheel in the diagram above.
    I now think of backspace simply as the depth from the mounting face of the wheel to the inside rim. Offset is the distance of the mounting face from the centerline of the wheel--that is, the distance that the mounting face is offset from the wheel's centerline. If the mounting face is moved from centerline to the outside, it is positive offset (and gives a greater backspace), and if it is moved to the inside, it is a negative offset, and the backspace is reduced.
  7. Smokin
    I like pictures.
  8. OrangeFist
    OrangeFist Member
    ok, so does that mean a higher offset number mean the wheel sticks out more?
    sorry if its a dumb question:confused:
  9. JustinP
    JustinP Member
    Other way around, smaller number for offset, wheel sticks out further. In truck applications, you'll Alot of times have negative numbers.
    OrangeFist and jimclark like this.
  10. OrangeFist
    OrangeFist Member
    Thank you!
