Overboost Feature
Discussion in 'Fiesta ST Chat and Discussion' started by Neely2005, May 27, 2014.
  1. I have my Aeroforce OBDII gauge set to read the post compressor MAP sensor. I'll have to find a better place to do acceleration differential.
    MH
  3. JRFist
    JRFist New Member
    either my boost guage is wrong (ap3) or what but when im cruising i see between -11 and -12 boost, when i floor it in 3rd gear i see a max of 5.00 and then steadies at 4.77. I dont know what im doing wrong
  4. Dyn085
    Dyn085 Active Member
    You shouldn't see -11/12 unless you're decelerating in gear. Even idling in neutral should be higher than that, let alone cruising.
    After reading this post though, it definitely sound like you're on the eco map.
  5. boost rooster
    boost rooster New Member
    Yea thats definitely eco mode. check a few threads up from this one "boost reading"
  6. Dyn085
    It's the same member, he had just posted in different threads.
