Post your datalogs in datazap !!
Discussion in 'Fiesta ST EcoBoost™ Tuning' started by sourskittle, Aug 14, 2014.
  1. sourskittle
    sourskittle Member
    I'll start.
    15,500 miles
    Sound symposer blocked
    Turbo-transformer
    Cobb ots tunes
    Ported exhaust manifold and turbine housing
    Miltek 3" catless downpipe
    Custom 3" catback with flowmaster 3"in/out
    Cut stock air box with factory oem filter
    100% Full weight fully loaded car. (3700# plus my 200#)
    89 to 87 degrees 100% humidty
    4th gear 2k rpm to 7k rpm
    93oct pump gas upto 10% eth
    235/40/17 tires ( ups the gear ratio and wheel/tire weight).
    http://www.datazap.me/u/Sourskittle
  3. ryst
    ryst Active Member
    You're only hitting 19.2 PSI?
    Woah, also 20 degree delta on coolant temp during just the 1 pull.
  4. sourskittle
    sourskittle Member
    Sounds about right with the boost with the weather here.
    I had not looked at the coolant temps, but that also doesn't surprise me with the weather and the duration of this run. Take your car out to BFE, bog it to 1400rpms in 4th geat and wot it and see how long it takes to get to 7,000rpms. Felt like it took 3 miles to get to 125mph, lol.
  5. razorlab
    You mean 2700lbs? ;)
    Do you have Accesstuner? *LOTS* of room to go your current tune.
    Good lord you need a FMIC upgrade.
    +40F charge temp gain over a 4th gear pull!??!?!?
  6. ryst
    ryst Active Member
    I'm pretty sure he's using OTS Cobb Stage 3. I'm going to try to pull a data log today, but this morning it was 50 degrees, and I was peaking at 22.8psi with Cobb Stage 2 OTS, and in 4th gear it holds 21+ psi from 2,000 to 5,000 RPM (until I lifted). This is my first turbo car, and i'm fully amazed how much of a difference ambient temperature makes.
  7. ryst
    ryst Active Member
    Alright, here's some logs:
    http://www.datazap.me/u/ryst/815-pulls?log=0&data=8
    12 and 13 are partial 4th gear pulls and log 14 is a full 3rd gear pull from 2300 rpm to 6500 rpm
    Cobb Stage 2 OTS
    93 octane
    Ambient temp around 75 degrees, low humidity
    No other mods
  8. ryst
    ryst Active Member
  9. razorlab
  10. sourskittle
    sourskittle Member
    But after it sees the same thing, TIME AFTER TIME, shouldn't that become LtFT and it know that its coming?
    I'm selling stuff around the house to buy access tuner btw, lol.
  11. razorlab
    It's a small event, and a short amount of time in the grand scheme of things. Usually LTFT is time based. Meaning, STFT has to be +/- a certain amount, for a certain amount of time to be added to LTFT and reset.
    Also, LTFT is for long term global adjustments, STFT is for very quick short term adjustments, like what we are talking about. :)
  12. sourskittle
    sourskittle Member
    Tin foe. I promise.... If I had access tuner, I'd load your tune and have datalogs tonight, lol.
  13. ISO100
    ISO100 Member
  14. ryst
    ryst Active Member
  15. ISO100
    ISO100 Member
    Yep. I plan to add that to the list of variables I log after I get it installed.
    After driving it a while I definitely feel more power at the higher RPM range even without a heat shield. It's a noticeable improvement.
    If it doesn't rain all damned weekend I'll be able to get some progress on the heat shield.
  16. Sekred
    Sekred Active Member
    Actually AIT is measured by the Boost/temp sensor in the tube between the IC and throttle body. The PID for outside temp is measure by a sensor located in the plastic radiator cowling behind the grill, RH side near the OEM air intake. Can't really see this sensor until you remove the bumper.
  17. razorlab
    That's the MAP sensor. Charge Temp is measured around there, post turbo/intercooler, Intake Temp is measured pre turbo/intercooler. Ambient outside temp is measured by the sensor you stated, behind the grill.
  18. Sekred
    Strange as it may seem and I had to check this with a heat gun but AIT which is shown as IAT on my OBDII scan tool is measured at the post intercooler pipe by the sensor I mentioned above, so its really charge temp. Out Temp from behind the grill which is different to the dash reading.
    I remove the MAF, stuck it in a length of pvc pipe and used the heat gun on this too. IAT temp didn't move, that's when I went looking further.
    MOFiST likes this.
  19. razorlab
    I think we are saying the same thing. :)
  20. Sekred
    OK, I understand you now. Technically a MAP sensor (manifold absolute pressure) is fitted to the intake manifold and this engine has a sensor in the intake manifold, don't know what Ford calls it because they call the sensor in the IC pipe a MAP sensor?.
  21. razorlab
    The sensor on the intake manifold could be another MAP sensor post throttle. To be honest I haven't taken the time to track down all the sensor locations yet. What I do know is that the sensor in the IC pipe pre throttle and post intercooler is a MAP sensor and the sensor pre turbo and post filter is the MAF sensor. Usually the pre intercooler IAT sensor is part of the MAF sensor as well.
