Push Button Start? (Euro Version)
Discussion in 'Fiesta ST Interior Upgrades' started by Robert, Apr 10, 2014.
  1. Robert
    Robert New Member
    Has anyone heard if this button is compatible with the U.S. model Fiesta ST as it definitely works for the Focus. Any ideas?
      File size:
      368 KB
      183
  3. dmondi12
    dmondi12 Active Member
    I just ordered one through fordpartsUK via email with Trevor, i told him my make and model and he sorted it out for me so hopefully i should get the button soon and i can report back on compatibility etc.
  4. moshaholic2
    I have one installed in my car. Ill try to grab the part # later.
    It didnt work in mine... So I just popped off the "Ford Power" button and snapped it into my original.
    The hardest part was getting the damn button out of the dash.
  5. D1JL
    Here is the correct part number for the FiST.
    I know that it is correct because I have one in my car.
    The part number is: 7S7T11572AC
    It is a Euro part so it can not be ordered from a US dealer.
  6. 70sstrat08
    70sstrat08 Member
    Dave, moshaholic2, any advise or resources for the install?
  7. limbo
    Do you mind sharing the cost to get it here to states?
  8. D1JL
    Mine was purchased from FordPartsUK.
    I am sorry I don't remember the price and I am sure it has changed.
    It is best to just Email and get current info.
    As was stated above, the hardest part was getting it out of the dash.
  9. quiznos
    quiznos Member
    How easy is it to get to the light? I want to replace with red and get the euro spec button
  10. moshaholic2
    There is a red euro spec button. Search the Focus forums for the part #. They have been doing this mod for a couple years now.
  11. quiznos
    quiznos Member
    Sweet. Lemme see what I can dig up.
  12. D1JL
    They only come red now.
    The blue was discontinued.
  13. quiznos
    quiznos Member
    Is it the light itself that's colored or the bezel?
  14. D1JL
    It is a lens inside.
  15. aborbs87
    aborbs87 Active Member
    For those that have installed this what type of technique did you use to get the bezel out of the dash. I am trying to install mine now, and the original will not come out. I swear it is like the damn bezel is glued in there. Help me guys! :(
  16. D1JL
    Brute force.
    t does just pry out.
    I might suggest that you put tape on the dash around the bezel to protect the dash.
    aborbs87 likes this.
  17. aborbs87
    Wow brute force and some wiggling did the job!
    I unfortunately have another problem. If you can help me again I'd really appreciate it. The new Ford Power button does nothing when plugged in, but the original still works fine? Any ideas :(
  18. D1JL
    Maybe you have a bad switch.
    Make sure all the pins are the same.
    If you ordered the part number listed above it is the same as what I have.
    Mine works perfectly.
  19. aborbs87
    Ok, so I checked all the pins and my order numbers everything looks good. Even the numbers on the two buttons match. I have the original installed and back in place with no issues. Meh I guess I just chalk it up. Thanks for all the help though!
  20. D1JL
    The switch part is the same.
    Why not separate the button top from the switch.
    Use the working switch and the button top you want.
    This also gives you access to the colored lens so you can choose if you want red or blue.
    quiznos likes this.
  21. quiznos
    quiznos Member
    Thanks again for the info dave
