Race wheels (not cheap)
Discussion in 'Fiesta ST Wheel and Tire Upgrades' started by wash, Aug 15, 2013.
  1. joe@2j-racing
    joe@2j-racing Active Member
    "As an FYI for Fiesta ST owners looking to use their stock wheels for winter and the stock summers tires on a new set of wheels, the 17x7 Pro Race 1.2 weighs 17.3 lbs. the 17x7.5 weighs 18.1 lbs and the 17x8 weighs 19.8 lbs. The Pro Race 3 rally wheel is available in 15x7 with a weight of 15.9 lbs, and a 17x7 with a weight of 18.1lbs."
    Mine weigh 19.8.. Their stats are wrong
  3. PCA-1
    PCA-1 Active Member
    Have sold sets over the past 3 years and not one customer has reported a weight variation. First I am hearing of it. Certainly will check with the UK.
  4. PCA-1
    PCA-1 Active Member
    What offset are your 17x7 Pro Race 3's?
  5. Fistofthebrownstar
    Fistofthebrownstar New Member
    Amen. the OZ ultraleggera are 12lbs each at 15x7, fyi
  6. PCA-1
    PCA-1 Active Member
    With 15x7 Team Dynamics Pro Race 1.2, weight is 13.7lbs, and the offset range available is 12mm to 45mm with the correct 63.4 hub bore, not needing hub rings like the Ultraleggera. As well, the Pro Race 1.2 is available in anthracite, gloss black, matte black, graphite, matte graphite, gold, high power silver, glitter silver, silver, and gloss white. Bronze, matte bronze, red, yellow, lime green, and orange are available at additional cost. Quality wise, the Ultraleggera is a low pressure cast, heat treated wheel and the Pro Race 1.2 is a low pressure cast, heat treated, and shot peened wheel. Finishes for both wheels are high quality OEM. Price wise, the 15x7 Ultraleggera is $205 each/$820 per set and the Perfect Circle Autosport price for the Pro Race 1.2 is $147 each/$588 per set, $232 less than the Ultraleggera and as good if not better quality.
    Also, for anyone interested in 15x8's, I have 4 sets in anthracite and 4 sets in matte black on order. Highest offset available is 35mm and the wheels on order are 35mm with the correct 63.4 hub bore. These wheels are part of the initial roll out of this size. Weight is 15lbs and pricing is $175 each/$700 a set. If anyone is interested in a different color or lower offset, like all other Team Dynamics wheels they can be spec ordered.
