Rally Armor Mud Flap Interest Thread
Discussion in 'Fiesta ST Exterior Upgrades' started by WRC Fan, Aug 24, 2013.
  1. Firesail
    Just got my RB's today haven't had the time yet to install. Going to be -2F here tonight. I don't want to be in the garage, too cold for me.:meh:
  3. scooby2
    scooby2 New Member
    I got my RB's today as well. I was surprised the logo was just a sticker included in the box and not something on the flaps. I'm hoping to have time this weekend to install them.
  4. Garrett
    Garrett New Member
    totally interested!
  5. stuntdoogie
    Got mine as well....but dont know when ima install them.
  6. Mayhem
    Mayhem Active Member
    Still, in for... whether or not metal gets drilled to install. :confused:
  7. stuntdoogie
    Anyone install the RB's yet?
  8. Firesail
    Installed mine yesterday. Fit well. Must drill 1 hole for front in the inner fender liner and drill out a rivet and enlarge 1 hole for the back on each side. Both holes should be 5/16". Instructions say different. There are some scrivets that need to be removed for the other holes. Be very careful with the ones in the rear, the tabs they are attached to are not real strong. Otherwise, went without a hitch and look great. You will need to remove the tires and wheels for best access. :)
  9. aborbs87
    aborbs87 Active Member
    Could you get away without the drilling, and use all of the other attachment points? Or is drilling needed in your opinion?
  10. stuntdoogie
    I was afraid of this. Didnt want to drill new holes in my liner. What if i wanted to change flaps to Rally Armor, dont wanna leave any holes exposed.
  11. Firesail
    The drilled hole in the front is the top one and goes into the plastic inner fender liner. in the rear, it is the bottom inner screw hole that stock is filled with a rivet. That rivet is in plastic. Drill out the rivet and enlarge the hole to 5/16". There is no drilling into metal involved.
  12. Firesail
    In the front I really don't see where you could get away without that top attachment point. On the rear, I wouldn't think that the two outer/upper points will hold the flap securely enough.
  13. spangenb
    Ordered mine. Normal length. Suppose I can always trim them if they end up too long for how far I lower the car.
  14. stuntdoogie
    Is there a gap between the fender and flap?
    Also how is the flap secured onto tje liner, do you have to get behind thee liner with a bolt of some sort so it doeant easily get ripped off?
  15. Firesail
    On the front, they have you install an insert in that upper hole. The mounting method seems solid enough.
  16. stuntdoogie
    You think they would get rippes off if you go through a machine carwash?
  17. Firesail
  18. ronnie karlen
    ronnie karlen New Member
    I'm in for info
  19. stuntdoogie
    Take some pics Firesail, cmon now :)
  20. Firesail
    Tomorrow after work.
    stuntdoogie and RodMoe like this.
  21. RodMoe
    Sweet thanks Fsail
