Scangauge Boost gauge
Discussion in 'Fiesta ST EcoBoost™ Tuning' started by WScottCross, Dec 24, 2013.
  1. djdennehy
    OBD 2 WiFi sensor from Amazon, $25
    Dash Command App from AppStore, $10
    Being able to monitor all vitals of car, data log, and dyno figures... priceless
  3. Fiat slayer
    Fiat slayer Member
    So I have and iPhone 5s and with the sensor and dash command I'll be able to monitor my cars vitals through my phone?
  4. djdennehy
    Yes. I use my 4s without issue, best part is that the dyno/performance meter is seriously accurate for being a cheap app. You can see any codes that come up, the display will show boost, MPH, temps, I mean...everything. Best cheap 'mod' (not even) I have done to the car.
  5. Fiat slayer
    Fiat slayer Member
    Witch OBD2 sensor did you get off amazon?
  6. djdennehy
  7. Fiat slayer
    Fiat slayer Member
    I bought it for only $7.56, now I just need to get the dash command app for my iPhone
  8. djdennehy
    When you get the OBD 2 device, the instructions to install it are on Amazon (another customer who is tech savvy wrote out instructions), follow them to get the device to talk to your phone, download the Dash Command App and it will all jive. I nearly purchased the Innovative OBD 2 wire that plugs into the iPhone for like, $200 bucks and this works just as well for a fraction of the price.
  9. jimlau
    jimlau Member
    I had a wifi ELM327 and DashCommand, but all I got for boost was a BOOST CALC value, that looked reasonable, but read the same on my ST as an SES, so I figure that couldn't be right. This was before the DashCommand update that added 2014 Fords to its database. Did you need to buy that to get accurate boost, or did I miss something? Thanks!
  10. djdennehy
    I just began using the app a couple of months ago so I didn't even know an update had been made...
  11. aar0n
    aar0n Member
    Ive used an EL327 with bluetooth and an old android phone. Only problem is I plugged it into USB to charge and it ran my battery down overnight and I am not sure how to remedy this :(.
  12. reddog99
    Ran down the battery of which one? The EL327, the phone, or the car?
